Michael_Her
- Sep 9, 2003
Can anyone suggest a good dvd to take along on a trip to Tweeter and the Home Theater store to look at DVD Players? I am going to go take a look at the Denon's and Mitsubishi.
If you want a lousy transfer that has poor cadence and bad flags, nothing beats Titanic!Oh, I don't know. 101 dalmatians II taught be every thing I ever wanted to know about combing. And the BMW Hire films are a close second in terms of my disc collection!
Side note: I own a Pioneer 45A (almost DFL in the Secrets shoot out). Sitting downstairs is a brand new Denon 1600 (second from the top in the shootout).
This evening, I will be having my own private shootout with the above mentioned discs. I figure that comparing the best to the worst should show me what all the buzz is about.
And if they look the same, I can then ether get my set ISF'd, or get me eyes ISF'd.
BGL
Brian_L please post your thoughts when you get done with this tomorrow, I have had several people recommend the 1600 to me.No conclusions yet. My brother in law came to town unexpectedly, thus cutting in to my geek time.
A couple side notes on the comparo. My TV has two component inputs, so I am going to connect both the 45A and 1600 at the same time, and tweak both inputs separately (my TV has memories for each). I am then going to rent a couple titles that I already own so as to be able to toggle back and forth.
Having said that, a couple problems have already popped up.
The 45A only passes below black in interlaced mode (I did not know that until last night. I thought it did NOT pass below black period.). The 1600 does pass below black in progressive mode.
That means that there could be slight differences in calibration between the two.
Next, I ran my initial calibration with the new Digital Video Essentials. While the color, contrast, and brightness patterns worked as expected, I find that the sharpness pattern requires (or maybe the right word is allows) a much higher setting than I even got with Avia or VE.
That applies to both players, but subjectively, I am not sure I like what I see with either player with the sharpness that high.
So, having said all that, since DVE is a relative unknown in terms of these new patterns, I will try to do the whole thing again tonight, but use Avia to calibrate.
One more variable. I have an attenuator on the Pbr line from the 45A. This helps address red push. I don't have that on the 1600 yet, therefore, even when I calibrate the 1600 to the color bar pattern, red still appears somewhat accentuated. I will need to get another attenuator for the 1600 to make this more like apples to apples.
I did play the first 1/2 of SW AOTC through the 1600 (after initial calibration) and it looked great. Very sharp, blacks looked inky, which is a good thing. Colors were vibrant, but again, I need to tweak the reds a bit. They may be too vibrant without the attenuator.
BGL
