Good center speaker for around $200
Discussion in 'Archived Threads 2001-2004' started by Whitney B., Oct 1, 2002.
  1. Whitney B.
    Whitney B. Auditioning
    Sep 15, 2002
    13
    I am looking at getting a center speaker for around $200.
    Nakamichi AV8 reciever
    Cerwin Vega mains (will be replaced soon)
    Boston Accoustic surrounds
    KLH sub (will be replaced soon)
    Primary input is DVD with 5.1
    Mainly I'm looking for quality.
    Any suggestions as far as brand, make, and model would help get me started. $200 is just a start I'm willing to pay more if I feel it's worth it.
    thank you
  2. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    I wouldn't get a center until I had purchased my new main speakers. You want the center to match your mains (timbre matching, same brand and manufacturer).
    For now, turn the center 'off' (i.e. phantom mode).
  3. Richard Harvey
    Richard Harvey Stunt Coordinator
    Jun 22, 1999
    172
    I disagree, somewhat. The center is so critical, you can certainly start with it and upgrade your mains later. But, I agree with Whitney that you'll want to at least go ahead and pick matching center/mains now, buy the center, and make sure you buy the matching mains in the future.
    A possible good quality speaker near your price range is the Boston Acoustics VR-910 center.
    Rich
  4. Adam Bluhm
    Adam Bluhm Supporting Actor
    Feb 9, 2002
    611
    Another wonderful center channel is the JBL S-CenterII. They are also timbre matched with all of the speakers in the JBL studio line.
  5. Valerie Brown
    Valerie Brown Stunt Coordinator
    Jan 5, 1999
    50
    You could also take a look at JBL's
    Northridge Series (the originals...
    not the IIs).
    The N-Center can be purchased for
    around $100.
    The NSP1 is the N-Center and 4 N24s
    speakers and can be purchased for
    around $200.
    You noted you were going to also replace
    your mains. You could purchase the
    some N38s for around $130 each and
    all your speakers would match.
    For less than $500, you could purchase
    2 N38s as mains and an 1 NSP1, add a
    sub and you would have 7.1.
    You could also by the newer Northridge
    Series IIs, but they would likely cost
    a bit more and are basically the same
    speaker.
  6. Anny Chien
    Anny Chien Agent
    Aug 27, 2002
    47
    Totem mite-T center got mine used for 200
    NHT AudioCenter-1, VS-2.4, VC-3 around 200-250
  7. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    I believe there's an NHT 1.2 on ebay right now for $100 or so...
  8. Patrick TX
    Patrick TX Stunt Coordinator
    Sep 12, 2002
    205
    I just replaced my front stage with Klipsch Reference, from Definitive ProTower, ProCenter. I'm SUPER happy with the center channel, fairly happy with the mains (RP5).
    http://www.reliableaudiovideo.com/kliprc3refce.html
    This is a great price, and the service was excellent as well.
  9. Whitney B.
    Sep 15, 2002
    13
    thanks for the input. i'm on my way to go listen to the vr910, vr920 and whatever else they have. would like to give energy a listen i've heard a lot of good things about them. let me know if anyone has any other ideas as far as what would suit me. 80%/20% movies/music. good quality center then later upgrade to the timbre matched mains. there is a boston acoustics vr20 on ebay i might look at as well as the vr-12. thanks
