Good banana's for bi-wiring?
Discussion in 'AV Receivers' started by Chris PC, Apr 5, 2004.
  1. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Now that I'm changing receivers around, I have gotten used to biwiring with bare wire as its my second time having to re-do the receivers speaker wire terminals, but it would be easier to have banana plugs. I may also want to compare receivers as I look at a possible "upgrade" and that would be easier done with banana's.
    What are good banana plugs that allow by-wiring without too much difficulty? Or do I have to simply fit two sets of wires in one banana plug?
    thanx
    [​IMG]
  2. ScottCHI
    ScottCHI Screenwriter
    Feb 21, 2004
    1,292
    if you can twist and fit 2 wires into one banana plug, that will work.
    "stackable" banana plugs ARE available, though.
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Well I assume there's always Radio Shack in Canada and you can also find some decent pricing on an ebay search specific to your country.
  4. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Yep. I'll check Radio Shack for those [​IMG]
  5. Jeff D.
    Jeff D. Supporting Actor
    Jul 10, 1999
    521
    Chris:
    Without doubt the best banana plug I have come across is the Deltron Gold. This banana uses a spring mechanism, as opposed to the standard "umbrella" style. It ensures a tight fit even after multiple reinsertions. We use these in our store, where cables are probably shifted 30+ times a day, and years later they are still as snug as day one.
    They also have a set-screw and crimp connection, ensuring good, solid, metal-to-metal contact.
    Jeff.
  6. ScottCHI
    Feb 21, 2004
    1,292
  7. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    I think I have the same deltron's right now at the speaker end of things. I'll look into more of those. They are gold in colour and they do have a set screw, though I can't recall if they have a spring. Whatever I can use to bi-wire will be sufficient. What piggy-backing? Is that plugging in a banana into the back of another? That would work.
    I'll check out the deltrons. Again, I must be able to bi-wire with them [​IMG]
    thanx for the info
  8. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
  9. Jimi C
    Jimi C Screenwriter
    Feb 22, 2004
    1,212
    110
    thats outrageous, theres no way that the actual cost is more than $4 a pack for those $114 banana plugs.
