I hate this time of year. Some days my eyes are bad enough that I can't wear my contacts and at night become VERY and itchy and dry. Anyone know a good over the counter allergy eyedrop?
I just had an opthalmology lecture that mentioned Opcon-A as being the best over-the-counter drops for controlling allergy symptoms.
He also said never to use more than one drop of any eye-drop solution--the eye can't hold the volume and the second drop would just wash out the first drop, wasting expensive medicine. Place one drop, close your eye, block the tear duct at the corner of your eye by your nose, and hold for two minutes.
Unless you have been diagnosed with allergies, you may want to consider getting an eye exam. I saw a bunch of nasty stuff that can mimic allergies. You want to be sure that it is not something more serious.
i was a long-time sufferer (i mean my whole life) until my wife essentially started forcing me to take prescription medication -- since my allergies were driving her crazy. for some reason, i just never thought about going to the doctor for a prescription.
now i walk around saying "flonase is your friend".
Patanol is the most commonly prescribed medicine for ocular allergies. The ophthalmologist here loves the stuff, but recommends Opcon-A as the most cost-effective solution for mild-to-moderate symptoms.
If it was me, I would try the cheap stuff first. If that didn't work after a few days, I would make an appointment to see an ophthalmologist.
I have allergies and was prescribed Naphcon until it went over-the-counter. It worked very well; though I used it in conjuction with Beconase (sp?) for the general symptoms. Is Naphcon a brand specific Opcon-A?
FYI: Patanol is a combination antihistamine and mast cell stabilizer. The stabilizing effect acts to prevent the release of substances which cause allergic symptoms (histamines and leukotrienes).
