Going from 5.1 to 7.1 -- Have Sunfire CG, Von Schweikert, PSB, Need 2 Speakers + Amps
Discussion in 'Archived Threads 2001-2004' started by Will, Nov 28, 2001.
  1. Will
    Will Guest
    I'm planning to get the Outlaw 950 pre/pro whenever it
    comes out and I currently have a 5 channel Sunfire
    Cinema Grand, which does 200wpc into 8 ohms, and
    400wpc into 4 ohms, and generally speaking, runs cooler
    to the touch than most amps.
    I can't decide how I'm going to power the other two
    channels. I can either buy a 2 channel amp, or replace
    my 5 channel Sunfire CG with a 7 channel amplifier.
    I like that the CG is famous for not running hot. I
    hope to get a total of 7 channels where the amplification
    does NOT heat it's enclosed cabinet.
    Currently, I have Von Schweikert VR 4 Gen II's in front,
    with a Von Schweikert center channel. For surrounds I'm
    using PSB Silvers. I need to get 2 more surround speakers
    but I'm not sure what brand to buy. I'm leaning towards
    maybe picking up 2 more PSB Silvers, perhaps used.
    Any advice?
  2. Bhagi Katbamna
    Bhagi Katbamna Supporting Actor
    Jun 1, 2000
    870
    I would get a quality stereo amplifier(perhaps a stereo sunfire) for the fronts and use the 5 channel amp for the center and surrounds. A seven channel amplifier(unless designed as 7 mono amplifiers in a single chassis) will usually have less power with all channels going than 2 separate amps that add up to 7 channels all other things being equal. How audible it would be is debateable.
  3. Steve Morgan
    Steve Morgan Second Unit
    Nov 10, 1999
    328
    Farm in Kansas
    Steve
    Will, Albert is starting to ship his new TS350 surround. Mine will go out Friday.It is a tripole design on the same plane as the Aerial 3s surrounds.A great match with the Gen III's.I have been waiting 4 months for mine and surround nirvana is almost her!
    Cheers,
    Steve
  4. Will
    Will Guest
    Thanks for the suggestions. Onecall has the Sunfire
    stereo amplifier for sale. It's on clearance for
    *only * $2000, which is a little too rich for my budget.
    The Von Schweikert TS-350 Surround Speaker is wall mounted
    but I don't want to tear up my walls to mount it. It goes to
    40 Hz so it probably needs to be mounted pretty well. I could
    I suppose put it on some speaker stands instead, but that
    doesn't seem too optimal. Besides, it costs *only* $2000
    a pair, which is at or just past the upper end of what I
    can spend for a pair of surround (or rear?) speakers.
    Any other suggestions?
  5. Will
    Will Guest
    Are there different requirements for side speakers than
    for rear speakers? The two new speakers could be used
    I guess, either on the side, or behind? Should I put
    the "better" speakers to the side, or in the rear?
    I'll be sitting relatively close to the rear speakers (about
    3 feet away), and somewhat farther from the side speakers
    (about 6 feet away). I'll be sitting maybe 10 feet away from
    the front speakers. That's how the room is layed out.
  6. Lee-c
    Lee-c Second Unit
    Sep 2, 2000
    497
    Will,
    A very cost effective solution would be to get an Adcom 5500 2 channel amp for your two new speakers.
    You can get one for around a 1,000. It'll do 350 watts into 4 ohms per channel continuous. A very nice amp
    for a wonderful price. That would make a great match for another pair of PSB silvers. Or you
    could go with the PSB minis, they would make great surround speakers. Very unobtrusive.
  7. Will
    Will Guest
    Thanks I'll look into your suggestion for an amp and
    speakers. If the stereo amp I get is less beefy per channel
    than my 5 channel Sunfire amp (which I think your suggestion is),
    I would probably use the stereo amp to power the side or rear
    speakers.
  8. Ricky T
    Ricky T Supporting Actor
    Oct 28, 1999
    921
    Will,
    You should be able to get the Harman Kardon Signature 1.5 200x2 amp for ~ $450-600 on ebay, HK direct, or places like jandr.com. The 1.5 has a DC trigger and should run cool/slightly warm. I think Adcom amps have a reputation for running warm (my adcom gfa5300 does in a open rack).
  9. Will
    Will Guest
    Ricky,
    Thanks for the advice to not get the Adcom amp
    since it can get hot to the touch, and to instead
    consider the HK Signature 200x2 amp.
    Will
  10. Will
    Will Guest
    Am I'm putting the cart before the horse?
    I could use the 7.1 pre/pro as a 5.1 processor and then not sooner but later, buy a new amp and speakers. I mean, I don't have to have 7.1 the day the 7.1 pre/pro arrives, do I?
