Ari
- Aug 3, 1999
I'm thinking of going FP in my 17'x22' dedicated HT. The NEC LT150 is right in my sweet-spot budget wise so I might go with that. I currently do not have a progressive-scan DVD player so I will have to upgrade. I'm not considering HTPC at the moment because of stability questions. I'm wondering if connecting the PJ to the DVD player is as simple as plugging in the component video cables to the PJ?? I hear stuff like scalers/line doublers and am wondering if I need to worry about these things as well. In order to ceiling mount the PJ, I will need around 40 feet of component video cable--do I need to worry about signal degradation?? The NEC needs a VGA to component-video adaptor--do you know where I can get this??
Thanks for any help/advice......
