Brian Mueller
Grip
- May 13, 2000
Greetings all. I'm about to upgrade my pre/pro, and along with that I'll be getting 7.1, which means at least a couple of new speakers. Since my uncooperative room layout means in-ceiling or in-wall for the new channels, and since those types of speakers are a bit more difficult to audition and return if you don't like them, I thought I'd try to get as many opinions as possible on my configuration ideas before I take the plunge.
Diagram A shows my current 5.1 layout, Paradigms all around (Mini-Monitor direct-radiators on shelves on the rear walls). The surrounds face each other directly. This isn't exactly ideal, but after some extensive tweaking this at least provides decent surround for the center seat. The seats on the sides miss out on most of the fun, and this is one problem I'm hoping to fix while I'm at it. Even for the center seat that "behind" effect is mostly missing, but I eventually managed to make it sound sort of behind instead of above or in front.
Diagram B is the first idea I had to incorporate the rear surrounds and fix some of these problems. It's got a new pair in-wall (or in-ceiling) speakers at the rear, with the Mini-Monitors aimed back out towards the room. This still isn't ideal, since the side surrounds aren't really quite on the sides, but I figured that this would at least open up the surround field enough to bring in the side seats while providing a "behind" effect that actually sounds like it's behind the seats. The biggest question if I go this route is in-wall or in-ceiling - since the seats are against the back wall, will in-walls go right over my head and create an "above" effect?
Since it was a slow week at work, I kept chewing on the idea and came up with Diagram C. This takes Diagram B and replaces the Mini-Monitors with in-ceiling speakers for the side surrounds. This allows me to get the side surrounds farther out to the sides, since my walls end but my ceiling doesn't. I think this would give better results than the previous idea since the speaker location would be better and include the side seats, but my concern here is that I won't like the sound I get replacing the Mini-Monitors with in-ceiling speakers. Here again also is the decision between in-wall and in-ceiling for the rear surrounds.
That wasn't enough, so I came up with the layout in Diagram D. Same idea as before, except that the side surrounds are moved up to the "middle" of the ceiling. I can't imaging that this would work very well, since the surrounds will probably sound like they're coming from the front, but I thought I'd throw it out there for discussion anyway.
As far as the speakers themselves go, for in-walls I might go with Paradigms to stay "in the family", but I might go Sonance instead (my dealer carries both), and in-ceilings would most likely be Sonance. That also raises the question of dipole or direct radiator if I go in-wall, since I've seen some recommendations that suggest dipoles for the rear channels (I'm not sure if Sonance or Paradigm make them, but I know I have seen in-wall dipoles somewhere).
Anyway, I'll be going to dealer for some extended discussions this weekend, but I trying to get as much feedback as I can in advance. I would love to hear any opinions or experiences, particularly if anybody has actually tried similar setups. My gut feeling is that Diagram C with in-ceilings for both side and rear surrounds would give the best results, but I want to be as sure as possible before I do it since it would be a bit difficult to change it once the speakers are in.
Thanks!
- Brian
Thanks!
- Brian
