DanKasun
- Aug 15, 2001
Hi all-
Wanted to get some feedback on the supposed glare on the Toshiba XXH81 (specifically the 57h81).
I'm really impressed with it right now, but can't test it out in my room where there is a large sliding glass window which might be a bad reflection source. I don't want to but it and then find out that this is going to be a problem... and I also don't want to wait and pay more for the xxHX81 if it doesn't make any significant difference.
So anyway, if you have one of these, can you please let me know how bad/not bad the glare really is. Here's a scale to help:
How would you rate it:
- glare on screen is hardly an issue in most cases
- glare on screen can be a problem in some lighting conditions, but is not a big deal
- glare causes pretty bad problems when there's a lot of ambient light or reflecting light sources, but is fine in low levels
- glare is a big problem, I have (or will) be removing the screen
Feel free to write in your own comments, of course.
Thanks - really appreciate any help.
-Dan
-Dan
