Hello, I will be getting a new hdtv today(finally saved the money). I would like a direct view, mainly because I play a ton of XBOX games and DLP is too much money right now.
I need the tv to be able to display 720p, because as you know many XBOX games are in 720p. Might I add it needs to be from Best Buy(cause of there credit plan). I have been looking at the Sony KV-36HS510. I looked under the specs and here is what it says "Hi-Scan 1080i? Display --- Sony's Hi-Scan1080i? TV's accept the full 1080 interlaced scanning lines (1080i) or 720 progressive scan (720p) from an external HDTV receiver or a compatible high definition digital satellite receiver. It also accepts 480 progressive (480p) scanning lines from compatible DVD video sources." The specs are located here:http://www.sonystyle.com/is-bin/INTE...ntentItemPage=
This set does support 720p right? Now another question. Stupid but simple..does it do it natively? What does natively mean? Does it mean that it isn't up or down converted from 480p or 1080i? Will there be a big difference if it is converted from a native image?
If so what direct view tv do you recommend from BB that will do 720p and still have a good image as Sony does? For around the same price.
Thanks for all your help!
Troy
Troy
