Getting PS2 to pass DTS to receiver
Discussion in 'Gaming' started by David Nguyen, Jan 17, 2004.
Tags:
  1. David Nguyen
    David Nguyen Stunt Coordinator
    Oct 24, 2000
    71
    I recently bought an Onkyo HTS660 for some relatives who will be using a PS2 as the DVD player, but I'm having trouble figuring out how to setup the PS2 so that it passes to DTS signal to the receiver.
    I looked in the manual, and went into the audio setup to turn the optical output on, and the dolby digital output on, but I can't get the DTS output option to light up so that I can select it and change it from off to on. I tried entering the menu using while playing different DVDs, but have had no luck so far. (I even used a DVD with DTS - Pirates of the Caribbean.)
    Am I missing something here?
  2. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    I haven't used my PS2 as a DVD player in a long, long time but I do remember that there is an additional audio menu on the PS2 when you insert a DVD...give that a try.
  3. TheBat
    TheBat Producer
    Aug 2, 1999
    3,087
    33
    1,610
    Jacob
    play a dvd movie then use the menus.. then go into steup.. then langauge.. then turn on both dolby digital and DTS..
    It should work.
    JACOB
