Paul Pratt
Hey everyone!
I just got a PT-AE500U Projector and i've been trying to get it hooked up for quite some time now. I've got it mounted and set up and the screen is set and all is good visually.
One bad thing though. Whenever i hook the projector up to my receiver and out of my subwoofer comes this immense humming like it's getting feedback.
Then when i hook up my laptop to get audio to the theater it brings out the humming in the speakers too.
The only thing is that it only happens with the projector hooked up. When i hook in the old 36 inch everything is fine. The same thing happened when i got the free trial of the X1 a couple of months back, but i didn't own it so i just dealt with it.
I've tried several different solutions. I've tried isolating the cables from one another, tried hooking everything up in different outlets, and the same outlet. I've tried surge strips, surge protectors, and power conditioners, and nothing. I've hooked each component directly into the subwoofer, even the projector, to see if i get feedback and I don't get a damn thing. I've tried crappy cables, and "good" cables, nothing seems to do it.
I'm lost and really need some advice and help.
Thanks folks!
Thanks folks!
