Get a new player or not, need some help??
Discussion in 'Playback Devices' started by Scott Goldsmith, Sep 4, 2004.
  1. Scott Goldsmith
    Scott Goldsmith Stunt Coordinator
    Sep 19, 2002
    209
    Currently I have a Denon DVD 1600, and I have been reading about players that upscale to 1080i, or better features, etc. I have a Mitsubishi 65" HDTV 65869 or something like that, can't remember off the top of my head, and all I can view movies in is 480p. I am using a Pioneer Elite VSX 53TX receiver, so any of the Elite payers with i-link won't benefit me [​IMG]
    What do you guys think I should do???
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    I'd stick w/ the 1600 atleast until reports are in on the Denon 1910, 2910, and 3910 and maybe pick one of those up depending on your budget (assuming your TV has a DVI input available). The 1600 is a great player so I wouldn't worry too much about what you're missing out on.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    What features besides scale'n to 1080i does you Denon 1600 not have?
  4. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    I'm not sure what your t.v. has, but if it doesn't have a DVI or HDMI input, you are limited to one player I believe that upscales DVD to 1080i through a high band component video input and that's the Zenith player.
  5. Scott Goldsmith
    Sep 19, 2002
    209
    My player doesn't play anything but DVD Audio, so I won;t be able to explore the SACD formats, etc.
    I believe my TV does have a DVI input on the back, it looks like a computer port correct?? I am just getting a little bored with my current player and was looking into my options, if nothing out there reasonably priced is worth it, then I will stick with the 1600.
    Thanks for the help guys, keep the info coming, if there is any [​IMG]
  6. Jerome Grate
    May 23, 1999
    2,984
    6
    110
    Based on posts here and other forums upscaling DVD players are definetly the rave of watching movies close to HD quality. I plan to get one and update my current 2nd generation Pioneer. I have two progessive scan players but both share vhs so I wouldn't put in the main HT. Anyway, maybe it would be worth waiting for the new line of Denon upscaling players.
