Get A Load Of This Subwoofer Shootout...
Discussion in 'Archived Threads 2001-2004' started by Chuck C, Dec 16, 2001.
  1. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
  2. Parker Clack
    Jun 30, 1997
    12,215
    58
    Kansas City, MO
    Parker
    Chuck:
    Thanks for the link. Great read.
    Parker
  3. Sean Conklin
    Sean Conklin Screenwriter
    Oct 30, 2000
    1,720
    Thanks Chuck that was good reading, AND, I now realize I need the SVS!
    My new mission is to somehow save up for the SVS!
  4. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Well there are a few things that I have some "beef" here.
    First of all 20hz signal won't give you a "punch in the chest",unless you laying next to the sub.[​IMG]
    I'm familiar with all of the demo scenes,especially the U-571,and I heard it on a few DIY subs[in the leuage of the SVS],and on WSR "Refernce Holosonic theatre",and none gave the chest thumping,instead they almost moved the floor,and shaked the couch[chair] I was sitting at the time,with the sense of all around you pressure in the air.
    Chest thumping is to me the same as boomy,which most dance clubs and commercial cinema features these days.
    The other thing,on the Velodyne graph.
    I thought the 20hz was at 102db versus 85db posted,and peaked @ 55hz at 113db,this wasn't even mentioned,and the 100hz "peak" was over 112db not 109db as posted.
    I assume these were typos,unless I'm missing something here?
    Also the fact that the Velodyne sounds "cleaner",it's a well known fact that they use "servo feeedback" to limit distorsion[usually @ 1%],and not to mention the limiter that is built in as well.
    While no doubt that the HGS-18 is a fine sub,for the money you can do better.
    Oh,yeah the SVS uses 12" drivers not 15".
  5. TerryC
    TerryC Stunt Coordinator
    Oct 19, 1999
    218
    Damn, that Klipsch RSW performed like crap! I was expecting this to be MUCH, MUCH, MUCH better as I assumed Deon Beardon(sp?) had a hand in designing it and he knows his stuff. I should have known a big corporate such as Klipsch can't make a decent sub and make enough of a profit and keep it under $2000. God bless SVS and Adire!
    Hey Lewis, how is your sub holding out? It would be right behind the SVS's in this test!
  6. Lewis Besze
    Jul 28, 1999
    3,134
    Hey Terry,
    it's doing fine.Yes it would be in the Ultra's neighborhood,for sure.
    I had sent an email to your work regarding it,if you can reply to my work email address,I will send it to you tonite.
    Thanks!
  7. David Head
    David Head Second Unit
    Jul 5, 1999
    302
    Thanks for the link Chuck. Reading about the SVS CS-Ultra just makes me want one even more! Too bad the Adire Dharman wasn't included...
    David
  8. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Well, it's really no surprize to me that that SVS combo did well in that company, you can almost predict the outcome before the test. (TV would probably disagree that the driver in the HGS18 is the "most highly engineered in the world [​IMG] ).
    As for the Klipsch RSW-15, I had wondered in another thread about it as to the adequacy of just one 15" PR with what was purported to be a very high excursion driver. I still have no idea as to the single PR's capabilities, but that kind of behaviour, the rolloff or compression as the sub approaches what I'd assume to be its tuning frequency, might be indicative of inadequate displacement. Just a guess, it could be a numbers of things, I suppose.
    Adequate displacement is also why I'd agree that Lewis' sub would probably do extremely well against these.
    A $549 Dharman against an HGS18 or dual-Ultra combo? Jeez, give the little thing a break. [​IMG]
  9. Kevin_W
    Kevin_W Second Unit
    Jun 22, 2000
    261
    Anyone have any idea what kind of room they tested these subs in? A dedicated sealed shoebox? The testers livingroom? [​IMG] I just wanted an idea of the cubic feet the measured results came from.
    Kevin
  10. Drew Bethel
    Drew Bethel Screenwriter
    Nov 22, 1999
    1,209
    Though it seems like the Adire is likely to be the new king 'o the hill other similarly priced products like the the vft-2, CT-150, PW2200, etc.
    The Adire has a lovely choice of finish as well...compared to my bland CT150!
  11. Kevin_W
    Kevin_W Second Unit
    Jun 22, 2000
    261
    Thanks Jack.. I totally overlooked that! :b
    Kevin
  12. Ryan Schnacke
    Ryan Schnacke Supporting Actor
    Feb 5, 2001
    876
    Lewis,
    I noticed the same thing. In fact, I couldn't find a single mention of [email protected] in the text that actually matched the data shown on the associated graph. What gives?
  13. Bergan Peters
    Bergan Peters Stunt Coordinator
    Dec 7, 2001
    145
    Sting as sub demo material? Uh yeah right. This guy needs to invest in a DJ Magic Mike CD or a Bass Mechanic CD. Otherwise those numbers are hard to argue with. Has anyone seen a modern test with
  14. TerryC
    Oct 19, 1999
    218
    I have a feeling the reason the graphs don't jive is because they likely didn't calibrate spectra to real world spl numbers and only used it as a frequency response test as it's really hard to calibrate it that way. They might hve used another SPL measurement device for those figures.
    Who knows I might be wrong?
  15. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
  16. David Head
    Jul 5, 1999
    302
    Jack,
  17. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    I thought all SVS's subs used 12" drivers as well?
  18. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    all the SVs use 12s right now...typo on the review. I'm sure they'll correct it when they have time,
    TV
