geometry problems... can it be fixed? 24" JVC
Discussion in 'Displays' started by AndyVX, Oct 5, 2003.
  1. AndyVX
    AndyVX Supporting Actor
    Aug 2, 2000
    804
    Hello,
    I just bought the JVC I'Art 24F704. I was watching my first DVD on it today, and I noticed that the picture was a tiny bit slanted. Like it has been rotated a degree or two counter-clockwise.
    After watching the DVD, I payed closer attention to cable TV, and it too is the same, though much harder to tell because the image still fills the whole screen.
    Anyways, is there anyway to correct this, or am I stuck with it the way it is?
    Thanks a bunch.
  2. Jonathan Dagmar
    Jonathan Dagmar Supporting Actor
    Dec 29, 2002
    723
    i have the same problem on my 27" jvs, and i think you are stuck with it, as JVC hasnt provided a tilt control on the service menu.
  3. AndyVX
    Aug 2, 2000
    804
    darn, oh well... guess I'm just gonna have to get used to it.
    thanks.
  4. Jeremy Scott
    Jeremy Scott Second Unit
    Mar 29, 2003
    292
    my 36" JVC I'art has a tilt control on it
  5. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,216
    3
    110
    Do you mean the service menu or the menu? the service menu should definitely be able to correct that, however you would either need a technician to do the work otherwise you void your warranty.
  6. Jonathan Dagmar
    Dec 29, 2002
    723
    i mean the service menu. I have been all through it amd found controls for everything but tilt.
    Void my warranty? Bleh. How are they ever going to know? That's just the type of crap they write in the manual to frighten joe schmoe away from doing something stupid... (been there, done that)
  7. AndyVX
    Aug 2, 2000
    804
    Ok, so how do I go about getting it serviced?
    I was doing one of those THX setup things (found on the Lion King DVD), and it also appears that the entire image is slightly shifted to the left. Guess that'll need to be fixed as well.
    Why can't they just make TV's correct right out of the factory? I mean, do they think that people will appreciate buying a set that is tilted and shifted one way or another?
    Thanks again.
  8. Jonathan Dagmar
    Dec 29, 2002
    723
    they think that most people are idiots that won't notice that TVS look like crap out of the box. and lucky for them, most people *are* idiots.
  9. Cagri
    Cagri Second Unit
    Dec 18, 2002
    415
    110
    Someone else in another recent thread was claiming that warranty becomes void if service menu is accessed.
    There's almost no way that the technician will know if the SM is accessed unless there's a log in the set where the factory settings are saved, which I doubt.
    OTOH, I got a replacement set by proving that my first set was used and I proved it to them by accessing the service menu. I even told them that I had to make lots of adjustments in there cause the geometry settings were way off.
    Note down your set's original settings when you get in there, and adjust the geometry w/o thinking the warranty. It's pretty straightforward once you know how to get access. Using a still test pattern makes it easier.
  10. AndyVX
    Aug 2, 2000
    804
    Ok, so then how do I go about getting into the service menu? Is there a code or something? Anyone know it off hand?
    Thanks a bunch.
    *edit*
    for that still test pattern, would using the circle test on the Lion King DVD suffice? It was that test that made me realize how off centre the image was.
  11. Gary SI
    Gary SI Stunt Coordinator
    Sep 2, 2003
    83
  12. Cagri
    Cagri Second Unit
    Dec 18, 2002
    415
    110
  13. AndyVX
    Aug 2, 2000
    804
    Thanks for the link... but I don't have a Video Status button on my remote, so I wont be able to get it to work. Is there any other way to get into it?
