genes new eq numbers as instructed
Discussion in 'Archived Threads 2001-2004' started by gene avallon, Feb 1, 2002.
  1. gene avallon
    gene avallon Stunt Coordinator
    Jun 13, 2001
    187
    Hz db
    12.5 87.5
    15 93.5
    17.5 100.5
    20 94.5
    22 90.5
    25 87
    28 87
    32 86
    36 83.5
    40 88.5
    45 91
    50 96.5
    56 95.5
    63 94.5
    71 91.5
    80 85.5
    90 90
    101 86
    113 89.5
    127 81.5
  2. gene avallon
    Jun 13, 2001
    187
    I did some corrections on my own,lets see how I did,
    the one third octave looks good?
    Hz db
    20 97.5
    22 93.5
    25 93
    28 95
    32 91
    36 82.5
    40 88.5
    45 91
    50 87.5
    56 91.5
    63 87.5
    71 91.5
    80 87.5
    90 90
    101 88
  3. Troy_K
    Troy_K Stunt Coordinator
    Jan 20, 2002
    87
    Gene,
    You really can't ask for any flatter response than that. Quite impressive. How do you like your "flat" response? Does it suit your taste, or is it just objective data that doesn't even sound right to you?
    I imagine you used an EQ to flatten out your peaks and valleys on the second set of data?
    Troy
  4. Nick P
    Nick P Second Unit
    Feb 11, 2001
    270
    I'm curious, what is the allowable +/- to be considered "flat". +/- 3db, 5, maybe 10? Only asking because I don't know. Looks like you've come a long way Gene. Congratulations!
  5. gene avallon
    Jun 13, 2001
    187
    hey I did good
    thank you
    gene
    :b :b
    after I put in the corrections I noticed quite a difference for the better.ok wayne what marks do I get, any touch ups?
    I used an art 351.wayne what about this plus or minus db to be considered ok.
  6. Jason Wolters
    Jason Wolters Stunt Coordinator
    Dec 18, 2001
    227
    What all are you using to conduct these tests?
  7. gene avallon
    Jun 13, 2001
    187
    strykes test cd,video essentials,art 351 eq,shack sound meter.
    gene
  8. gene avallon
    Jun 13, 2001
    187
    should I knock down the 97.5db at 20hz a little? I thought a little louder down there wouldnt hurt much.
    gene[​IMG]
  9. Mark Austin
    Mark Austin Supporting Actor
    Dec 28, 1999
    639
    Which sub are you testing?
  10. gene avallon
    Jun 13, 2001
    187
    two 46 plus with art351
  11. Wayne A. Pflughaupt
    Aug 5, 1999
    6,183
    51
    9,110
    Katy, TX
    Wayne
    Nick,
  12. Nick P
    Nick P Second Unit
    Feb 11, 2001
    270
    Wayne,
    I know it's next to impossible to have a completely flat response but if one has a variance of as much as 10db is that still considered flat or is some EQing then needed. In Gene's case, which looks great Gene, he has an 11db swing from 22-36hz and then a 9.5db swing from 36-71hz. Since I'm new to the idea of EQing I'm just wondering if this is considered "flat".
  13. gene avallon
    Jun 13, 2001
    187
    ok guys here we go.
    HZ db
    20 95.5
    22 92.5
    25 90
    28 93
    32 92
    36 88.5
    40 90.5
    45 90
    50 95.5
    56 92.5
    63 90.5
    71 91.5
    80 90.5
    90 91
    101 90
    I dont now but these look great that 36Hz null is smaller,yes? I like doing this.
    gene
  14. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    Wow! Those are impressive. If I'm not mistaken that makes your's +-3.5dB. That ain't too shabby. How are the measurements below 20Hz? Hopefully someone with a better understanding of this stuff can explain your peaks at 50Hz and 20Hz with the dip at 36Hz. I'm guessing it has something to do with your room size.
  15. gene avallon
    Jun 13, 2001
    187
    there just great below 20 but the art only goes to 20,and below that I cant hear it but I sure can feel it.the dips and peaks are getting better with each new setting. the two 46 plus have a lot to do with the nice readings im getting.I can leave the meter on one setting for the whole works,couldnet do that before.
    gene
  16. gene avallon
    Jun 13, 2001
    187
    hey wayne people like what were doing,student and teacher
    gene
