CRyan
- Feb 9, 1999
OK. Well, I know enough about cars to perform general maintenance but that is about it. I had the spark plugs replaced several months ago in my wifes 99 Civic EX.
A few weeks ago, I looked over the car before taking a short trip. Well, I found that one of the spark plugs was loose (glad I checked). The tube through which you place the plug had gotten black and corroded and the spark plug wire had deteriorated somewhat. I replaced the plugs myself with the correct torque of course and did not think too much about it.
Well, I called Honda where I usually have my oil changed and asked them about the issue. They said that the black corrosion was crystalized oil and that there are gaskets under the plugs that should be replaced because they are probably deteriorated just like the spark plug wire. Sounds reasonalbe I guess.
I just wanted to know what anyone here thought about it. What are these gaskets (seals) called? They want $90 to replace them. Is this reasonable? Thanks for any input.
Also, on a side note. Why in the world are spark plug wires so expensive. I was going to replace them myself, but the cheapest set I could find was for $63. Hell, Honda will replace them for me for $70.
Thanks again,
C. Ryan
Thanks again,
C. Ryan
