general bi polar questoin
Discussion in 'Archived Threads 2001-2004' started by Matt Weldy, Jun 19, 2002.
  1. Matt Weldy
    Matt Weldy Second Unit
    Feb 4, 2002
    335
    Are bipoler speakers what I want to be using for my rear surrounds. I have the def tec pro monitor 80 as my side surrounds (this is because of a lack a wall in the correct place and had to hang from the ceiling.) But my question is should i get bi poles for the rears or just get another set of direct rad. 80's
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    depends. I know thats a horrible answer but its the best we can do. There's a multitude of factors to consider from DD and DTS's recomendations, to your room layout and your preferences etc that all come into play. IMO if you don't have a proper back wall I'd lean towards direct rads but there might be a case for bipoles as well.
  3. Matt Weldy
    Feb 4, 2002
    335
    Its not that I dont have a back wall. ITs that I dont have a side wall. As you are looking at the tv its the left wall thats missing.
