GBA-Low battery warning?
Discussion in 'Archived Threads 2001-2004' started by Chris Bardon, Feb 3, 2002.
  1. Chris Bardon
    Chris Bardon Cinematographer
    Jul 4, 2000
    2,059
    Just wondering-does the GBA have some sort of low battery warning on it? I'm asking because I know that the GBC doesn't, and I've lost quite a few games in progress due to the battery shutting down on me before I had a chance to save.
  2. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    The GBA "power on light" changes colour when battery power is getting low. From green to red, I believe.
  3. Dan Brecher
    Dan Brecher Producer
    Jan 8, 1999
    3,450
  4. Chris Bardon
    Jul 4, 2000
    2,059
    Really-that's better than the GBC with its light getting a little dimmer (but with no point of reference). Score one for the new machine!
  5. Jeremy Illingworth
    Jeremy Illingworth Supporting Actor
    Nov 12, 2000
    535
    And then it flashes red if you want to play it to death.
    jeremy
  6. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    Actually, mine flashes red first, when the batteries first start to go out, then it changes to solid red, then solid black. [​IMG]
  7. Morgan Jolley
    Morgan Jolley Lead Actor
    Oct 16, 2000
    8,818
    122
    9,110
    It should be noted that using things like lights will not drain the battery faster (they will, but not too fast), but will make the unit think that, so the light will be red, but when you turn the light off, it turns green.
