Gasket tape: local source?
Discussion in 'Archived Threads 2001-2004' started by Greg_R, Feb 4, 2002.
  1. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    Does anyone know where I can get some foam gasket tape? (local HD doesn't have any) I'm remounting my sub driver and don't want to spend $5 shipping on a $3 item. Thanks!
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    I’m sure HD has something suitable. Check the aisle where weather stripping is sold.
    If not, you can use rope-caulk. It’s a little messy when you take the speaker out, but it makes a great (and air-tight) seal.
    Wayne A. Pflughaupt
  3. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Yes, Lowe's or Home Depot weatherstripping section. Get black, CLOSED cell foam gasket tape, 3/8" or 1/2" thick x whatever width that is most suitable for your driver's flange width. The rope caulk actually seals great, a bit messy and takes a little longer and usually you only find it in white - I don't know if it's made in black.
