Greg_R
Hi everyone,
I was listening to my DIY sub and it started making loud banging sounds (not good). This was a surprise since it's been working for 3+ months. As far as I can tell, the seal on one of the PRs developed a leak and was causing the PR to travel in a non-linear fashion. I've taken out the driver and PRs and nothing looks damaged. So, how do you recommend sealing the driver/PRs onto the box? Obviously the stock gasket didn't work. Should I remove it and use silicone caulk under the bare metal flange? Any other suggestions? Thanks in advance for the help...
