Coming soon, my own Weber Cook's Deck
Hoa approval done. County paperwork next. Then get it built late May.
I am definitely considering a ceramic cooker. The one I want is the Primo Oval XL. It is quite expensive....Chuck Anstey said:I'm curious about whether anyone here has considered going with a Big Green Egg, other ceramic cooker, or simply a charcoal grill? In the old days, a "top end" gas grill might cost $275, which was less than half of the BGE and ilk. But today's gas grills seem to start at the cost of a ceramic cooker and then just go insane after that. I made the switch 8 years ago and I love it and it was all about the cost as I finally had enough money to buy one. My previous one had rusted out and I just didn't care to get a new one. To me, meat on gas grills at best taste like cooked meat and at worst taste like gas and would never mistake it for the the taste of meat cooked over lump charcoal. Not to start a debate about which is better but more of an observation that gas grills seem more about the size of the grill than the quality of it or the food it cooks.
I'm the beta tester. Being rolled out in select markets next Smarch.Johnny Angell said:Dave, I don't see that deck being offered on the Weber site as an accessory.
I'm trying to execute a Dennis Nicholls:Step 1) bought house and build awesome deckStep 2) ???Step 3) ProfitStep 4) buy wang doodle super grillIf Step 2 requires house in Cal, and a law degree, I'm boned.Dennis Nicholls said:Gee whiz Dave, don't go cheap on us now! http://kalamazoogourmet.com/products/hybrid-fire-grill/gas-grills-not-hybrid/
That is clearly illegal in most areas.DaveF said:I'm trying to execute a Dennis Nicholls:
Impressions are good. Top notch materials, at no time during the assembly did I or my neighbor think, that's cheap. It took the two of us about 3 hours. I'm a klutz with stuff like that, but my neighbor Steve is sharp with things like that. I have no buyers remorse.Mike Frezon said:Overall impressions, Johnny? Materials, etc.
How long did it take you to put it together?
Don't forget grilled asparagus, which is cheap this time of year. Use direct heat for the stalks and indirect heat for the flowers. Rub some peanut oil on them first (highest flashpoint cooking oil).schan1269 said:Corn on the cob, cooked in the husk?
That is the best...mmmhhhhmmmm.
I understand there's a price on my head in certain jurisdictions, such as MA and NY.Mike Frezon said:That is clearly illegal in most areas.
You'll notice I said most.
That should work. (It's what I would do) youay have to play with settings and timing a couple of tries to get it just so. Maybe rotate the ribs to gel even cooling, since there will be some heat gradient from middle to side. As for the grates: I saw that triangle shape at the store. I think you want flat side up. But I'll have to play with it this summer.Johnny Angell said:I was just thinking, if need a bigger indirect cooking area. What if I turned the left burner off, turned the only lit burner (the right) up more to maintain the temp I want. Than put the ribs over the center and left burner for the duration.
I haven't cooked this way, despite recommendations. For net effort, I like to husk, liberally salt and butter, and grill wrapped in foil. Comes out good. I should try the in-husk method this year.schan1269 said:Corn on the cob, cooked in the husk?That is the best...mmmhhhhmmmm.
