Gameport Error
Discussion in 'Computers' started by Rich Romero, Mar 22, 2005.
  1. Rich Romero
    Rich Romero Supporting Actor
    Jun 6, 2002
    731
    I have two gamepads that just won't work. Both are connected via USB. One is a Logitech Dual Action Gamepad and the other is a Nyko airflow. The computer simply won't even recognize that they are plugged in. Furthermore, if I try to add them manually, I get this error "Gameport or gameport drivers not properly configured, please consult device manager." Anyone know what the problem is?
  2. Bob_L
    Bob_L Supporting Actor
    May 19, 2001
    891
    2
    Bob Lindstrom
  3. ChuckSolo
    ChuckSolo Screenwriter
    Jun 26, 2003
    1,160
    If the error message is telling you that the "gameport" is not active, then that means that the USB hardware is either, A) defective, or B) the hardware USB driver in the OS or BIOS is either not not loaded or enabled respectively. It's not the device you are trying to plug in, it is the actual USB ports that are not working.
  4. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Yeah, get that 'device manager' open. If you can't figure out what is wrong, and my USB ports gave me a bad time once too, do what I did. I just deleated them! When you reboot, Windows will reload the drivers automatically.
    Glenn
  5. ChuckSolo
    Jun 26, 2003
    1,160
    Rich, although Glenn is correct, you should go up to the website of the motherboard's manufacturer and get the drivers they have for your OS. Many times the drivers are not native to the OS, especially Win2K. [​IMG]
