Game Cube Compnonent Cable: Progressive only??
Discussion in 'Archived Threads 2001-2004' started by Scooter, Dec 3, 2001.
  1. Scooter
    Scooter Screenwriter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    I just went to the Nintendo website to get this cable...thus my question. Are the Cube games only progressive??? Thing is, My 400Q doesn't do progessive..at least I don't think it does.
    Any tips?
  2. Michael St. Clair
    May 3, 1999
    6,001
    No, only about half of the Cube games are progressive at all, and even those will optionally allow you to do 480i through the component outputs.
  3. Scooter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    Thanks..just ordered it!
  4. Morgan Jolley
    Morgan Jolley Lead Actor
    Oct 16, 2000
    8,722
    115
    Thanks dad! Can't wait to get my cable!
    BTW, in Rogue Leader, there is an interlace option (which I assume is for the component cable). Does anyone know if this is progressive and thus won't work on our projector???
  5. Brandon_H
    Brandon_H Stunt Coordinator
    Aug 25, 2001
    234
    After you've got the component cables hooked up, the menu will allow to select between sending out an interlaced or progressive signal. If you use any cables other than component cables you won't get the choice.
  6. Rusty Ray
    Rusty Ray Second Unit
    Jun 26, 1999
    273
    yes, Morgan the interlace option is progressive, if you have the cable installed you will be able to choose it but if the set doesnt support it, well you know... but still on its own the component cables will make a big difference in the quality of the colors, sharpness, etc. (but you prolly already know that!) [​IMG]
  7. William Ward
    William Ward Supporting Actor
    Mar 1, 2000
    701
    Once the component cables are plugged in to the cube most games will give you the option of progressive scan. Madden 2002 has a simple progressive y/n choice in the settings menu.
    Looks fantastic too.
  8. Morgan Jolley
    Oct 16, 2000
    8,722
    115
    Just got my cables today, try them out later. Thanks for the info!
    So I got my PS2 component cables, my GCN cables, now all I need is an X-Box and component cables!
  9. Jim__B
    Jim__B Stunt Coordinator
    Jan 2, 2001
    148
    Just got my cables today. All the games looked great except madden. Does any one have a problem with Madden having a black bar at the bottom when in Progressive mode? Before the cable it waws all set up for widescreen and there was no problem, now with the cables there is a black space at the bottom. I am using a Mitsu 55807
