The two DVDs are virtually identical. I thought the two mixes seemed largely the same; the DTS version might have a small edge, but not by much. If I were to purchase one or the other, I'd go with the DTS one, but I wouldn't replace the DD copy if I already had it.
All of the extras are also identical...
Colin Jacobson
DVD Movie Guide www.dvdmg.com
I had problems with the DD crackling in the center channel (which I understand was a common problem, yes?), but the DTS does not seem that bad in the center channel.
------------------ Yes, but are they high-quality balloons? ~ David Letterman
Clinton, that crackling you mention is present on both the DD and DTS versions. It is not a problem per se with either encoding scheme, but instead a problem inherant with the original mix in a couple spots where the microphone was overloaded during recording. Comparing both soundtracks, they are very very similar. With either one you won't go wrong.
J
I agree, if you are deciding now on which to get, go with the DTS version.
Personally I happened to get the DD version (happened to find it used in a store and picked it up at a good price) and am very happy with it, but if they were both on the shelf I'd go with the DTS.
/Kimmo
