Gah! I hate Outlook!
Discussion in 'Archived Threads 2001-2004' started by Joel Mack, Feb 27, 2002.
  1. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    So there I was, working happily along on my work laptop and port replicator (using Outlook Express as my e-mail program), when the system board started failing. I was able to backup all of my e-mail, address books, bookmarks, etc.
    However, when the local support folks re-imaged my machine, I got stuck with regular Outlook (the corporate standard). I've looked high & low, and can't find a way to import all that saved stuff into Outlook. Am I screwed? Is there another way?
    Any help would be appreciated....
    Thanks!
  2. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    It could be worse, they could be using Lotus Notes! [​IMG] (where's that puke smiley when I need it?) [​IMG]
    There should be an option in Outlook to import your address books. If not, look and see if Outlook Express is on the machine. It might be there but there's no shortcut to it on the desktop/start menu. If it isn't, just grab IE from the MS web site and reinstall it. It comes standard with Windows, so you should be able to install it.
    KJP
