ethan_l
- Oct 25, 2002
I have the HCM-4215W
when I do that convergence
I noticed that the points on the side seems a little fuzzy
this is especially true when doing the Blue part
I don't know if all rear projection uses the same type of
adjustment but on mine
you have several points (crosses) on the screen
and under each cross is a little color cross that you can
adjust to match the one on top
it's the lighter cross that's fuzzy
