Fuse Box Breaker
Discussion in 'Archived Threads 2001-2004' started by armin, Feb 18, 2002.
  1. armin
    armin Extra
    Jan 29, 2002
    16
    Hi,
    I am going to run all my equip on one line, DVD, Receiver, VCR, Sony 11HT.
    Should I be wary of anything. Do I need to up the amps on the breaker or should the normal (15AMP??) suffice
    armin
  2. Greg_W
    Greg_W Stunt Coordinator
    Jul 6, 2001
    54
    No, they will be fine on just one fifteen amp breaker. But if you are building, and can run 12 gauge wire a 20 amp circuit wouldn't hurt to be future proof.
    Greg
  3. JohnRice
    JohnRice Lead Actor
    Jun 20, 2000
    8,850
    230
    It will depend somewhat on how efficient your speakers are and what receiver you are using. In general, today's receivers (which is your biggest power draw) are incredibly efficient. As long as you aren't using large external power amps, you should be fine. If you could get the TV on a different circuit, it would probably be a good idea, though.
