Fully HD Capable w/o additional receiver
Discussion in 'Archived Threads 2001-2004' started by Mark S T, Mar 29, 2002.
  1. Mark S T
    Mark S T Auditioning
    Mar 5, 2002
    5
    To get Time Warner HDTV cable they say I need a Fully HD capable without the pruchase of an additional receiver. Pardon my ignorance, but most TVs say HD ready. Does that mean they won't work because they need an additional receiver? If that is true what sets are Fully Capable or what language instead of "HD ready" should I look for describing the TV? I don't recall seeing any that said Fully HD capable.
    Thanks as always for all the expertise available in this forum. If only DVI would go away so I could buy my set tomorrow.
    Mark
  2. Jeremy Engel
    Jeremy Engel Extra
    Mar 8, 2002
    19
    There are some 16X9 sets that have built in hd tuners for ota signals. They are specifically called hdtv's. All hd ready tv's need additional recievers to view hd. I thought that Time Warner provided you with their hd receiver, I don't think you can just plug a coax cable into a hdtv and be set. I may be wrong though. How would time warner be able to unscramble the premium channels without their decoder box?
  3. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Ask what kind of outputs does the cable box deliver the HDTV from.
    To get HDTV out the box must have either component video or RF output.
    If there are component video jacks, any TV that takes both 1080i and 480p will do.
    THe S-video output jack will deliver only SDTV (480i NTSC). HDTV shows will be downconverted.
    Just because the cable box has an antenna coax output does not mean that HDTV is delivered from it without downconversion. If the RF output to TV, or antenna coax, does deliver HDTV as HDTV as well as regular SDTV channels, you need a TV with built in HDTV tuner or a separate standard HDTV set top box.
    Video hints:
  4. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    Don't worry, your HD ready set will work fine with TWC hd box....You do not need any additional receivers...
  5. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
  6. Andrew s wells
    Andrew s wells Second Unit
    Nov 20, 2001
    449
    How much is the time warner HD box?
  7. Michael Reuben
    Feb 12, 1998
    21,763
    2
  8. Mike I
    Jan 20, 2000
    720
    TWC charges the same monthly rate for their HD box as their digital cable box..I believe around 10 a month
  9. Mark S T
    Mar 5, 2002
    5
    Thanks,for all the good information. Especially the part about not needing to worry about the TV being HD ready. I wondered why if I am on a waiting list for the set top box why it wouldn't have a receiver in it. I have also heard rumors that TW may make me subscribe to special pay per view channels in order to get the HFTV box. So we'll see.
  10. Bryan Shelley
    Bryan Shelley Auditioning
    Mar 28, 2002
    I just got the Time Warner HDTV cable box( Explorer 2000HD). You will need an hdtv ready tv, but You will not need your own tuner. I have'nt seen the new 3000 box yet, but the 2000 can be configured to output either Y Pb Pr or RGBhv. You'll have to let the techs at TWC know what inputs your set needs. good luck.
