Ed Werner
- Apr 19, 2003
I currently have:
Integra DTR 8.2
Running:
Polk RT600i mains
Polk CSi40 center
Polk RTi50 surrounds
Polk PSW 650
I was thinking of:
Replacing my mains with RTi 70's if I can ever find a pair, and adding two more subs.
Currently I have the PSW 650 running off of the LFE, but if I buy two more subs, then I was thinking of hooking it up as such:
Putting each of the new subs in the front corners, then running the speaker level input through them for each L/R speaker respectively. This would leave a L/R on each open. Then Bi-Wiring my center and running one wire each thru each sub, and then to center.
Using the rear surround wires through the speaker level inputs to the psw 650 then to the rears. (more "normal" type setup)
Setting all speaker outputs to "Large".
What do you guys think? I will still get all the LFE effects from movies correct? Or will I be missing out on the buttshakin bone rattling type effects?
I figure say if there is an explosion in the front R part of the movie, bass and sound will come from that respective speaker/sub. If it is directly center, it will come though both front subs. If it is behind, then the PSW should take care of that (I am guessing there would be residual type bass also from the subs that aren't directly in line with the movie effects?)
Its just and idea that I have been kicking around for a bit now since I am close to upgrading my mains. I am happy with the psw 650, got a great deal and it hits hard, low and sounds very nice behind the loveseat. I think the only place I need to fill with bass is the front even though the sub does a descent job of bouncing the bass off the walls from the rear.
This is an 13x15 room by the way, and not a dedicated home theater, but my living room complete with a couch (left side), loveseat (rear and best sitting postion), recliner (right side), two end tables, coffee table, audio rack and 57" hitachi HDTV.
Yep its tight but I will sacrifice an end table if I have to.
Sorry so long, and if any details are needed I will be happy to provide.
Ed
Integra DTR 8.2
Running:
Polk RT600i mains
Polk CSi40 center
Polk PSW 650
I was thinking of:
Ed
