Full control pre/pro?
Discussion in 'Archived Threads 2001-2004' started by Dennis B, Mar 29, 2002.
  1. Dennis B
    Dennis B Stunt Coordinator
    Nov 1, 2001
    189
    Folks,
    I own a Marantz SR7200 that I'm using as a pre/pro and while I'm not really looking into pre/pros right now (I'm getting better speakers first) I was wondering if there's a reasonably priced pre/pro out there that will let you have fully adjustable controls and still be at least 5.1/DD/DTS, etc. No more fixed xover @ 100 Hz, 15 ms distance intervals, stuff like that. Geez, this almost sounds like Office XP, won't let you do anything on your own.[​IMG]
    Thanks.
  2. chung
    chung Stunt Coordinator
    Feb 23, 2002
    234
    Sony STR-DA5ES.
  3. Jerry Klawiter
    Jerry Klawiter Screenwriter
    Dec 3, 2000
    1,412
    The B&K Ref 30,
    See it here
    They can be found used at $1700-$1850
    Not sure what you mean by reasonably priced?
    Very cool and variable interface.
    Even control/set it up within windows with the B&K
    software suite.
    Works well under Windows XP
    One of the best values around and it's made in the USA[​IMG]
  4. Dennis B
    Nov 1, 2001
    189
    Jerry,
    Thanks, seems like a nice unit. Do you have any idea how it would sound compared to my SR7200. I mean, the Marantz sound is very addicting in spite of all the other problems...
  5. Jerry Klawiter
    Dec 3, 2000
    1,412
    I have not compared it with the Marantz.
    B&K is a very smooth/warm/detailed sound.
    I have had a Sony Ta-E9000ES and the B&K just blows that out of the water as to music, The Sony was to bright, although it had an in your face processor for the action movies.
    I also have a Denon AVR-5700, the Ref 30 is warmer then the Denon.
    It's to bad that B&K does not have any info
    about their Suite software online,
    I have never found it.
    If you check around you should be able to find
    somewhere to down-load it and check it out.
    Or stop by a deal and get a copy.
    It has a emulation mode, This way you get a good look
    of the workings of the B&K units, It supports most
    of their current products.
  6. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    New NAD receivers due out some time this year might have better bass management. Currently, NAD receivers have a 100 hz crossover. Hopefully they will provide at least a selection including 60 and 80 hz.
  7. Dennis B
    Nov 1, 2001
    189
    Just out of curiosity, do the $10,000+ Krells, Lexingtons, etc have the kind of bass management the 5ES does?
