In all seriousness, I'm not familiar with that abbreviation, so have no idea what an "FTA receiver" might be. Maybe others are in the same boat, hence the lack of replies.
All you need to do is do a Google search for FTA, but it is a satellite receiver that picks up Dish Network channels...LOTS OF THEM. FTA stands for Free To Air.
My experience with Google is that entering a simple three-letter combination like "FTA" can return a million completely unrelated responses, and deciding which one is relevant can be tricky when the whole reason you're Googling is that you're not familiar with the term. But thanks for the tip.
Yes there are the Pansat and Fortec receivers. They are most common. But mine is not C-Band, I can tell you that much. It uses a standard sized satellite dish and I think C-Band uses those much larger dishes.
