Scott_Condon
- Feb 11, 2004
Toshiba SD9200 DVD-A/V Player $350
Video
10-bit 54MHz Video D/A Conversion with Super 4:4:4 Processing
Super ColorStream Pro® Progressive Component Video Output
Aspect Ratio Control
Custom Picture Settings
Horizontal Resolution: 540 Lines
ColorStream® Component Video Outputs
S-Video Output
Composite Video Output
Parallel Video Output (Interlaced)
Audio
24-Bit 192kHz PCM Audio Compatibility
DVD-Audio Decoding and Playback via 6 Channel Analog Outputs
HDCD® Precision Filtering and Decoding
Built-In Dolby® Digital Decoding with 5.1 Channel Analog Outputs
3-D Digital Noise Reduction
Optical Digital Audio Output
Direct Audio Mode
Dolby® Digital & DTS® Compatible Digital Output
Coaxial Digital Audio Output
One Pair Analogue Audio Outputs
Dynamic Range Control
Parallel A/V Outputs
Convenience
NAVI Menu
Picture Capture
Preview
Angle Viewer
Strobe Picture
QUICK Menu
DVD-Video/DVD-Audio/VCD/CD/CD-R Playback
DVD and CD Text Compatible
First Setup Menu
High-Mass Copper Shielded Chassis
Performance Matched Components
Universal Remote with Toggle Control
Virtual Remote Control
Remote Confirmation
X2 Playback
Slow Motion, Forward and Reverse
Parental Lock
Time Search
Icon-Based On-Screen Displays
Camera Angle Select
Multi-Language Select
Multi-Subtitle Select
Title Stop
$350
Video
S-Video Output
Audio
Direct Audio Mode
Convenience
NAVI Menu
Picture Capture
Preview
Angle Viewer
Strobe Picture
QUICK Menu
First Setup Menu
Remote Confirmation
X2 Playback
Parental Lock
Time Search
Camera Angle Select
Title Stop
$350
