FS: subs
Discussion in 'Archived Threads 2001-2004' started by chris_hunigan, Jul 10, 2002.
  1. chris_hunigan
    chris_hunigan Stunt Coordinator
    Jul 2, 2002
    89
    I have (2) 12" SVS/FRC subwoofers that I would be willing sell. These are normally around $130 at www.svsubwoofers.com. I would be willing to go $85 each for the 12" drivers. Take both 12" drivers for $160 shipped. However, please email me!
    Here are the T/S Parameters for the 12" drivers.
    Qts: .41
    Vas: 152L
    Fs: 21.5Hz
    Re: 3.2ohm
    Xmax: 13mm
    Z: 4 ohm
    Qms: 6.720
    Qes: .44
    SPL: 88.35 dB
    Pe: 300rms / 600peak
    BL: 10.65
    Dd: 22.57 cm
    Sd: 510 cm^2
    Mms: 132 g
    For more info on the 12" drivers, they can be found here http://www.svsubwoofers.com/parts_woofer_isd.htm These are 4 ohm SVC drivers.
    I will tell you what the (2) 12" drivers have never been used! I was going to build a 20 cu ft sub sonotube sub enclosure, but I never did have the time to make it last year. So I they have been in our storage room for over 1.5 years. They are brand new.
    The reason why I want to get rid of these is because I have no room for them and I have no need to keep them in my apartment. The drivers are practically like new! The 12" drivers have not been used at all.
    I don't have a digital camera to take some pictures of the drivers, however, you will very impressed with the build quality of these drivers.
    CreeDiddy
  2. Johnny Garvin
    Jul 2, 2001
    32
    YGM
  3. Jason Hammerly
    Jason Hammerly Supporting Actor
    Oct 28, 1999
    739
    I'm confused. How are they the new and improved driver that retails for $129 that have only been available since mid December and you've had them for 1-1/2 years in storage. Just curious? Thanks
  4. chris_hunigan
    Jul 2, 2002
    89
    Jason, just emailed you!
  5. ThuanVu
    ThuanVu Stunt Coordinator
    Jan 31, 2001
    208
    If the 12" are CSi (improved version) then I'll take it
    Please let me know
    Thuan
  6. chris_hunigan
    Jul 2, 2002
    89
    No these are not the CSI models. These are early version.
    Email for more info.
    CreeDiddy
