Studio monitors JBL 4345 $5.999
Low used. Standing in a non smoky room. The 4345 is original, come with its original drivers and crossers, works very great in good condition.
Scheme
4 ways, 4 loudspeaker bass-reflex scheme, and a floor type
Unit:
For low-pass: 46cm cone type (2245H)
For inside low-pass: 25cm cone type (2122H)
For mid-high ranges: Horn type (2420+2307+2308)
For high regions: Ring type (2405)
Frequency characteristic: 32Hz-20kHz±3dB
Directivity (horizontal x vertical): 60 degrees x 30 degrees (-3dB, 16kHz)
Output sound pressure level: 95dB/W/m
Impedance: 8ohms
Allowable input:
120W (at the time of a network)
200W (multi-amplifier Lo)
100W (multi-amplifier Hi)
Cross over frequency:
320Hz, 1.3kHz, 10kHz (at the time of a network)
290Hz, 18dB / oct (at the time of multi-amplifier)
Enclosure dimension:
253L (Woofer)
14L (mid Woofer)
Dimensions: Width 765x height 1096x depth of 470mm
Weight: 140kg (at the time of an packaging)
[email protected]
Scheme
Unit:
Impedance: 8ohms
Allowable input:
253L (Woofer)
14L (mid Woofer)
[email protected]
