Alain.P
Grip
- Aug 28, 2003
Sony SCD222ES 5 CD changer SACD player comes complete with original box
$250 US Value $800.00
The SCD-C222ES uses 3 advanced Super Audio D/A converters for multichannel SACD playback. The audiophile-pleasing result of all this processing power is multichannel sound that's breathtakingly pristine and dynamic. One of these high-end converters also handles two-channel playback — stereo SACDs sound phenomenal, and your regular CDs come to life with extraordinary detail.
Beefy ES construction helps this player produce its exceptionally clean sound. The anti-resonant aluminum front panel squelches unwanted vibrations, while an R-core (round core) power transformer minimizes flux leakage and hum. Load up any combination of SACDs and CDs, and you're off to new audio realms!
Key Features:
5-disc changer
plays multichannel SACDs, stereo SACDs, CDs, audio CD-Rs, and audio CD-RWs
multichannel bass management and level control
3 Super Audio DACs
single lens with separate optical pickups for SACD and CD
SACD/CD Text display
R-core power transformer
analog outputs for SACD (5.1-channel) and CD
optical and coaxial digital outputs for CD
remote control
SACD playback specifications:
frequency response 2-50k Hz
0.0018% THD
104+ dB dynamic range
16-15/16"W x 5-7/16"H x 17-3/8"D
NHT SC1 center Speaker $175 US Value $300
Two 4.5-inch woofers / 1-inch dome tweeter / Frequency response of 78Hz – 22kHz +/- 3dB / Handles up to 150 Watts power
# NHT's Super Audio Series SC1 Center Channel Speaker adds a critical centerpiece to your Home Theater audio speaker array. Rear Channels add a startling dimensionality to Surround encoded Music or DVD-Video soundtracks, but the center channel is what brings the media to life. This center channel speaker is voice-matched to all the other channels in the Super Audio Series, and fits excellently into surround systems of many makes and designs. A 1-inch metal dome Tweeter is flanked by two 4-1/2" long-throw Polypropylene woofers for smooth, coherent sound
# Acoustic suspension enclosure enhances tonal accuracy and tight Bass response
# Magnetically shielded
# Frequency Response: 78Hz – 22kHz (± 3dB)
# Designed for maximum accuracy when playing either music or Digital video soundtracks
# Handles up to 150 Watts of amplifier power
# 5-Way binding post connectors
# High-gloss black lacquer finish
# Dimensions: 5-11/16"H x 16-9/16"W x 6-11/16"D
Product Specifications
Type of Component | Speaker - Center Channel
What is the purpose of a center channel speaker? | Reproduces center-channel in HomeTheater
How many drivers in center channel speaker unit? | 3
Size of Driver in Center Channel unit? Inches/Diameter | 1 Inch
Size of 2nd Driver in Center Channel unit? Inches/Diameter | 4-1/2 Inches
Size of 3rd Driver in Center Channel unit? Inch/Diameter | 4-1/2 Inches
How much power can Center Channel Unit handle? | As much as 150 Watts
What is the cabinet color of Center Channel Unit? | High Gloss Black
What is front-grille color of Center Channel Unit? | Black Color
About how high is Center Channel Unit? Inch | 5-11/16 Inches
About how wide is Center Channel Unit? Inch | 16-9/16 Inches
About how deep is Center Channel Unit? Inch | 6-11/16 Inches
Pioneer SDF-3K speakers $70.00 US
Features
8" (200mm) 2-way Bookshelf Loudspeaker
High Frequency Waveguide for Controlled Directivity
Gold Plated 5-way Binding Posts for High Connectivity
High Efficiency Tweeter for Increased Dynamics
Bass Reflex Cabinet for Extended Lows
Magnetically Shielded for Use Near TV
Contoured Vent for More Punch
Black, Woodgrain Finish
Removable, Black Grille
ISO-Drive Baffle System
Designed and Engineered in the USA
shipping from Montreal Canada
Key Features:
5-disc changer
3 Super Audio DACs
remote control
0.0018% THD
Features
