Thomas P.
- May 20, 2002
I bought a 19" Sony Wega LCD Monitor in June, 2005 from Best Buy. I have used it very little. I thought I would use it as a small monitor with a DVD player for my wife. She prefers her laptop. The Display has Best Buy extended, transferable warranty.
The monitor is a KLV-S19A10 -
Flat Panel Type LCD
Screen Size 19 inch
Display Resolution 1280 x 768 pixels
Digital TV Standard HDTV-Ready - Requires separate receiver to view HDTV signals.
Broadcast Format Displayed 720p (HDTV) • 480p (EDTV) • 480i (SDTV)
Broadcast Format Supported 1080i (HDTV) • 720p (HDTV) • 480p (EDTV) • 480i (SDTV)
Built-in Tuner NTSC
Native Aspect Ratio 15:9
Interpolated Aspect Ratio 4:3
Remote Control
Comb Filter 3DYC / 3D Digital
Adjustable Color Temperature With Adjustable Color Temperature
Audio Type Virtual Surround
Audio Output Variable / Fixed
MTS Stereo SAP / MTS Stereo
Audio Leveler With Audio Leveler
Picture in Picture Without PIP
Parental Control V-Chip
Sleep Timer
Energy Star Compliant
Input Connectors S-Video x 2 • Component x 1 • Composite x 2 • Audio (RCA) x 3 • RF x 1 • Audio (Mini Jack) x 1 Connectors S-Video x 1 • Composite x 1 • HDMI x 1 • Audio (RCA) x 2 • D-Sub (RGB PC) x 1
Rear Output Connectors Audio (RCA) x 1
Headphone Jack With Headphone Jack
Screen Text
With Channel Labels
Number of Speakers 2 Speakers
Speaker Power 2 x 5 Watt
Dimensions
Width 18.33 in. Depth 3.31 in. Height 14.33 in.
Weight 14.77 lb.
Overall Warranty 1 Year
Cabinet Color Silver
Los Angeles preferred for local pick up. $799 OBO. Call Tom at 323.571.0073.
Thanks.
Flat Panel Type LCD
Screen Size 19 inch
Built-in Tuner NTSC
Remote Control
Sleep Timer
Screen Text
With Channel Labels
Dimensions
Weight 14.77 lb.
Thanks.
