Michael D. Bunting
- Jun 9, 1999
- Michael
Sony STR-DG800 7.1 A/V Receiver
Sony 7.1 Channel Home Theater Receiver, Model STRDG800
The STRDG800 Home A/V Receiver delivers the digital world to your living room and beyond. Enjoy hundreds of channels of crystal clear digital radio with XM® Connect-and-Play™1. With 770 Watts-110 Watts X 7 this receiver is truly a powerhouse and coupled with Digital Cinema Auto Calibration setup is a simple as connecting the supplied microphone and pressing a button.
Features:
* HDMI™ Passthrough
Powerful HDMI connectivity allows for uncompressed audio and video to pass through directly to your television.
* XM® Connect-and-Play™
A World of digital radio is at your fingertips. Connect the optional Connect-and-Play antenna, sign up for XM service and enjoy the variety of digital radio with the superior sound quality of an A/V receiver.
* Digital Cinema Auto Calibration
Now the optimal speaker for your living room is only a press of button away. Simply place the included microphone in your listening position and allow the strength of Sony’s Digital Signal Processing to take over. Speaker placement, distance, and delays are all adjusted automatically to ensure a worry free listening experience.
* Portable Audio Enhancer
Simplified front audio and video connections are part of what makes the STR-DG800 ideal for today’s portables. Beyond the simplified connection a powerful Digital Signal Processor is used to expand the quality from any device that is connected.
* Digital Cinema Sound™
Sony’s original Digital Cinema Sound technology uses exclusive DSP technology to recreate the precise environment of three Hollywood Dubbing Stages where your movies are created. True theater sound in the home from the source.
* Component Video Up Conversion
Allows for composite and S-Video sources to be converted to component video output, minimizing the number of connections needed from receiver to your Television set.
Specifications:
Audio
* Impedance: 8 Ohm
* Channel Power Rating: 770 Watts-110 Watts X 7 (8 Ohms,THD 0.7%), 700 Watts-100 Watts X 7 (8 Ohms, THD 0.09%)
* Sound Fields: Cinema - 3; Music - 4; Auto Format Decoding - 11; 2 Channel - 1
* Zones: 2 Zone/2 Room
* Tuner Type: Auto Tuning, Direct Tuning, Station Name
Inputs And Outputs
* S-Video Input(s): 3 (Rear)
* S-Video Output(s): 1 (Rear)
* Composite Video Input(s): 5 (1 Front, 4 Rear)
* Composite Video Output(s): 3 (Rear- 1 Monitor Output, 2 Video Outputs)
* Optical Audio Input(s): 4 (1 Front, 3 Rear)
* Optical Audio Output(s): 1 (Rear)
* Coaxial Audio Digital Input(s): 2 (Rear)
* RCA Audio Input(s): 8 (3 Dedicated, 5 Audio/Video)
* RCA Audio Output(s): 3 (Rear-2 Audio/Video Outputs, 1 Output)
* Multi-Channel Input(s): 1 (Rear, 7.1 Channel)
* Subwoofer Output(s): 1 (Rear)
* AC Outlet: 2 (Rear) Switched
* Antenna Terminal (AM Loop): 1 (Rear)
* Antenna Terminal (FM 75 Ohm): 1 (Rear)
* Headphone Output(s): Yes (Front- Gold)
* Speaker Terminal Type: Screw Binding Posts (A & B)
* HD Component Video Input(s): 2 (Rear)
* HD Component Video Output(s): 1 (Rear)
* HDMI™ Connection Input(s): 2 (Rear)
* HDMI™ Connection Output(s): 1 (Rear) Switcher
Power
* Power Requirements: AC 120V, 60 Hz
Audio Features
* Digital Cinema Sound™ Technology: Yes
* Dolby® Digital Decoding: Yes
* Dolby® Pro Logic® II Decoding: Yes
* dts® 96/24 Decoding: Yes
* dts® NEO:6 Decoding: Yes
* Dolby® Digital EX Decoding: Yes
* Dolby® Pro Logic® IIX Decoding: Yes
* Dolby® Pro Logic® Decoding: Yes
* dts®-ES Decoding: Yes
Convenience
* AM/FM Memory Presets: 30 FM - 30 AM
* XM® Connect and Play™ Compatible: Yes
* XM® Memory Presets: 30
* Sound Fields: Yes
* A/B Speaker Switch: A / B / A+B
* Digital Cinema Auto Calibration: Yes (Mic- Mono)
* HDMI™ Technology: Pass-through
Hardware
* Remote Control: Yes
Video Features
* Up Conversion: Yes (Component Up Conversion from S-Video and Composite)
Supplied Accessories:
* Instruction Manual
* FM Wire Antenna
* AM Loop Antenna
* Size AA Batteries: 2
* Pre Programmed Macro capable Remote Commander® Remote Control
Approximate Dimensions:
* Width: 17"
* Height: 6-1/5"
* Depth: 13-5/6"
Approximate Weight:
* Unit: 25 lbs 6 oz
* Shipping: 29 lbs
In excellent condition...and works perfectly. It was used only for a handful of months before I upgraded to a dedicated Pre/Pro setup in my HT. It was purchased from Best Buy on 11/25/06 for $399.99 It will ship double-boxed (the original Sony retail box is included, but it is a bit beat up).
Asking Price: $225.00 Shipped!
Payment via PayPal or Money Order
Shipping via UPS Ground (Included)
[email protected]
Features:
* HDMI™ Passthrough
Specifications:
Audio
* Impedance: 8 Ohm
Inputs And Outputs
Power
Audio Features
Convenience
* Sound Fields: Yes
Hardware
Video Features
* FM Wire Antenna
* AM Loop Antenna
* Width: 17"
* Height: 6-1/5"
* Depth: 13-5/6"
Approximate Weight:
* Unit: 25 lbs 6 oz
* Shipping: 29 lbs
[email protected]
