Terry.P
- Nov 6, 2002
Awesome preamp processor/Dolby Digital and surround decoder. Great condition. Comes with remote and manual. Asking $175 plus shipping. Purchase with confidence. My eBay id is "tlp-123".
Here are the specs.
The Sony SDP-EP9ES surround processor/preamp was an astounding accomplishment: musical sound from a $799 list processor, with performance to rival processors costing thousands of dollars more. "ES" = Elevated Standard, Sony's top of the line.
Features
Dolby Digital (AC-3®) decoding for surround sound that is far more dynamic, spacious and realistic; generates 5.1 separate channels of line-level sound for Left, Right, Center, Left Surround, Right Surround and Subwoofer
Digital Dolby Pro Logic surround decoding brings home all the excitement and emotional impact of movie sound tracks; decodes and amplifies all the surround channels already encoded in most movie videocassettes, many TV dramas and sports broadcasts
Automatic processing selection senses when the incoming signal is Dolby Digital encoded and automatically applies the correct decoding; for conventional PCM digital audio, defaults to Dolby Pro Logic decoding
Digital Cinema Sound system -a Sony exclusive that recreates the precise acoustics of real movie production dubbing stages at Sony Pictures Studios in Culver City, California; you'll hear movies the way the producers and directors heard them
Digital Cinema Sound 3D processing overcomes limitations in rear speaker placement with Virtual Enhanced Surround, Virtual Rear Shift and Virtual Multi Rear effects
24-bit digital processing decodes the full dynamic range of Dolby Digital sound tracks; exceeds the processing capabilities of previous Dolby Digital decoders; uses 53rd-order x2 FIR filtering for superlative accuracy; performs 44 million digital calculations every second
Speaker size setup with bass redirection compensates for inability of many rear speakers to handle the full 20 to 20,000 Hz frequency response of Dolby Digital surround channels; redirects surround bass to the front speakers or subwoofer; 16 possible settings for complete system flexibility
Rear-channel stereo
Six-channel test tone for system alignment
Digital crossover control with five crossover frequencies for bass redirection
Digital "i" volume control regulates current to achieve a full 20 bits of resolution at every volume level
Digital balance control for superior accuracy
Independent digital bass and treble controls for front, center and surround channels
Full Feed Forward Digital Filters with 3-stage oversampling for reduced requantizing noise; filter uses 8x oversampling, 45-bit internal processing and 20-bit outputs
Current Pulse Digital-to-Analog Converters use highly accurate current source for greater precision than voltage sources, greater immunity to power supply voltage fluctuations
Ultra-Rigid Frame & Beam Construction reduces the spread of vibration inside the chassis for reduced microphonics in low-level stages, purer sound
Anti-resonant insulator feet with off-center drilling to minimize the transmission of shelf-borne vibration
Set-up Wizard steps you through the process of initial set-up; makes sophisticated adjustments easy
20-character dot matrix display for accurate, informative function readouts
Motorized master volume control with indicator LED
Three Optical Digital Inputs to accommodate DVD Players and other Dolby Digital sources
Coaxial Digital Input for high-quality digital-to-digital connections
Single Optical Digital Output for high-quality digital-to-digital connections
Dolby Digital RF Input Demodulator for Dolby Digital decoding with compatible Laserdisc players
Analog Outputs: Front L/R, Center (2), Rear L/R, Subwoofer
Bypass Inputs: Front L/R, Center, Rear L/R, Subwoofer. Allows hookup of existing surround processor or preamp.
Here are the specs.
Features
Rear-channel stereo
