- Jul 19, 2002
I'm selling a nearly new Sony DA-4ES receiver. It was purchased in March and I started using it in June. It's a great receiver. I still have the original box, remote, all the paper work, and the original sales receipt. I can provide pictures for those interested, but it is in perfect condition.
It has 4 years and 7 months left on it's 5 year warranty and it was purchased from Sammans, which is an authorized dealer.
I'm asking $500 + shipping from 40456 or it could be picked up in Mt. Vernon, KY before Aug 15 or in Atlanta, GA after Aug 15 (School's just around the corner :frowning
. Shipping would be around $60 (it weighs 55lb) depending on location.
E-Mail any questions to [email protected] or contact me through AIM at nehpets4627.
Key specifications are as follows:
- dual 32-bit processors for surround decoding (Dolby Digital EX, DTS-ES, Pro Logic II, DTS 96/24), DTS Neo:6 and Digital Cinema Sound modes
- 110 watts x 7 into 8 ohms (20-20,000 Hz) at 0.05% THD
- multi-brand LCD remote with macros
- dual-room/dual-source A/V capability (composite video and
- stereo preamp output for second room)
- video conversion (composite to S-video)
- 7.1-channel preamp output
- 5.1 and 7.1-channel inputs
- RS-232C port
- component video switching: 2 in, 1 out (50MHz bandwidth)
- digital inputs: 4 optical and 2 coaxial
- optical digital output
- 4 audio (including phono) and 5 A/V (including 1 front panel and 5 S-video) inputs
- stereo and multichannel analog direct modes
- digital and video power management
- Control A1II & S
- on-screen display (requires TV with direct video input)
- OP (Optimum Pre-amplification) Processing ensures a high signal-to-noise ratio at all volume levels
- wide-range frequency response
- frame-and-beam chassis
- Sf (S-fin) heat sinks
- over-sized power supply and transformers
- aluminum front panel
- two 12V triggers
- IR repeater: 1 in, 2 out
- 2 sets of main speaker outputs
- banana plug-compatible terminals for all speakers
- 16-7/8"W x 6-15/16"H x 19-11/16"D
- RS-232C port
- Control A1II & S
- two 12V triggers
