FS: Samson S700 Amp $250 Shipped
Discussion in 'Archived Threads 2001-2004' started by James Elvick, Aug 4, 2002.
  1. James Elvick
    James Elvick Supporting Actor
    Jan 12, 1999
    690
    Great amp without question. Comes with the original box, receipt and manual. It is in excellent condition. $250 shipped in the upper 48, PayPal or MO.
    Produces 350 watts a side into 4 ohms (stereo or "parallel" mode) and 700 watts into 8 ohms bridged mono mode (bridging not recommended for single SVS CS series subs)
    Two ultra-quiet, temperature-sensitive, speed-controlled fans
    Stable bipolar design with torroidal transformer
    3-segment output LED meters
    Front panel input level controls with 42 detents
    Soft turn on, relay-controlled outputs linked to the protection LEDs
    Banana jack outputs with Speakon (tm) connectors
    XLR and locking TRS 1/4" inputs (RCA to 1/4" Pro-Grade Us Made interconnect included with all Samson amp/sub combos!)
    Unique "parallel" input mode allows mono bass signal connection to run both channels for seamless dual sub setups!
    User re-settable fuse protection
    Removable rack mounting tabs allows you to rack or stack
    Dimensions (with rack fittings removed) 17 1/4" Wide, 16" Deep, 3 1/2" High (Note: Dimensions on Samson materials are incorrect)
  2. Brian AM
    Brian AM Stunt Coordinator
    Jan 9, 2002
    86
    I'll take it.... send me your paypal address at [email protected]
  3. James Elvick
    Jan 12, 1999
    690
    SOLD!
    James[​IMG]
