FS: QSC PLX-3402 & PARADIGM X-30 XO (1 Viewer)
Kurt Ferguson
I tried posting this once and it isn't showing up, will delete this post if other one shows up.
Hey guys. Trying to get rid of some excellent equipment that I simply no longer have a use for.
The first item is a QSC PLX-3402 PA Amplifier.
I am posting rough specs below, you can see complete specs and amplifier information here: QSC - PLX Series Amplifiers
SPECIFICATION
PLX3402
STEREO MODE, Both Channels Driven
8 ohms (20 Hz-20 kHz 0.03% THD) 700 W
4 ohms (20 Hz-20 kHz 0.05% THD) 1100 W
2 ohms (1 kHz 1% THD) 1700 W
BRIDGE MONO MODE
16 ohms (20 Hz-20 kHz 0.1% THD) 1400 W
8 ohms (20 Hz-20 kHz 0.1% THD) 2200 W
4 ohms (1 kHz 1% THD) 3400 W
Signal to Noise (20 Hz-20 kHz) < -107 dB
Input Sensitivity @ 8 ohms 1.9 Vrms
Input Sensitivity @ 4 ohms 1.7 Vrms
Voltage Gain 40x (32 dB)
Output Circuitry 2-Step Class H
Power Requirements
(1/8 Power Pink Noise @ 4 Ohm) 12A
ALL MODELS Distortion (SMPTE-IM) Less than 0.01%
Distortion (Typical)
20 Hz-20 kHz: 10 dB below rated power: Less than 0.01% THD
1.0 kHz and below: full rated power: Less than 0.01% THD
Frequency Response
20 Hz-20 kHz, +/- 0.2 dB / 8 Hz-50 kHz, +0, -3 dB
Damping Factor
Greater than 500
Input Impedance
6k ohms unbalanced, 12 k ohms balanced
Input Clipping
10 Vrms (+22 dB)
Cooling
Variable-speed fan, rear-to-front air flow
Connectors, each channel
Input:
3-pin XLR & 1/4" TRS balanced
Output:
Neutrik® Speakon® and touch-proof binding posts
Amplifier Protection
Full short circuit, open circuit, thermal, ultrasonic, and RF protection
Stable into reactive or mismatched loads
Load Protection
On/off muting, DC-fault power supply shutdown
Dimensions
19" (48.3 cm) rack mounting, 3.5" (8.9 cm) tall (2 rack spaces)
13.25" (33.7 cm) deep (from front mounting rails)
Gain
40x (32 dB)
Weight
21 lbs (9.5 kg) net, 27 lbs (12.3 kg) shipping
The amplifier is in excellent condition, save for a minor surface scratch on the bottom of the amp, which is shown clearly in a picture below. The amplifier has been well cared for, and is in fully functional condition. Power cord is included. I paid about $1200 for this amp brand new.
Here are the pictures for the amp:
[url=https://static.hometheaterforum.com/imgrepo/3/34/htf_imgcache_27402.jpeg] [/url]
[url=https://static.hometheaterforum.com/imgrepo/0/0c/htf_imgcache_27403.jpeg] [/url]
[url=https://static.hometheaterforum.com/imgrepo/a/aa/htf_imgcache_27404.jpeg] [/url]
[url=https://static.hometheaterforum.com/imgrepo/8/8f/htf_imgcache_27405.jpeg] [/url]
The other item that I am selling, is a Paradigm X-30 Crossover.
This is a fully active XO
OUTPUTS:
HP 3x(pair) - 50Hz, 80Hz, 120Hz (stereo) - 12dB/octave
LP 1x(pair) - 35-150Hz Variable - 18dB/octave
INPUTS:
1x(pair): Line level RCA (stereo)
CONTROLS(LP out only):
Phase Control - 0 - 180 degrees
Level Control - -70 - 0dB
LP Frequency - 35 - 150Hz
All 3 HP outs can be active at once. I purchased this at a local retail audio shop for $175+tax. I no longer have the original AC adapter, but a suitable variable AC to DC adapter will be supplied with the unit. Also included, although not pictured, is the original single 20' shielded RCA cable that came with the unit. There are some very minor surface scratches, one on the top of the unit, in the upper left corner, and one on the front of the unit, at the very top, between the two dials. I have circled both scratches, although the front one is VERY hard to see.
Here are the pics of the XO:
[url=https://static.hometheaterforum.com/imgrepo/8/8c/htf_imgcache_27406.jpeg] [/url]
[url=https://static.hometheaterforum.com/imgrepo/6/62/htf_imgcache_27407.jpeg] [/url]
[url=https://static.hometheaterforum.com/imgrepo/d/d8/htf_imgcache_27408.jpeg] [/url]
I would like to sell them both as a pair, for $850 + shipping. This is a great deal on some great gear. I will also consider selling them seperately, cost for the amp would be $750, and $100 for the XO (plus shipping). I will accept buyers for both over seperate, as that's what I prefer to do. I am NOT interested in ANY trades, so please don't bother emailing me or messaging me with trade offers. I need money, not trades. You can either respond on the forums or simply email me at [email protected] for a faster response. You can also message me on AIM, my SN is drakhi
I have been a member of these forums for over almost 7 years, but I really haven't ever posted much. I am quite active and have been for a number of years on car audio forums such as caraudioforum.com caraudio.com sounddomain.com and carsound.com so don't worry about me trying to rid you off. Just trying to get rid of some gear I no longer need. Thanks!
GuSR_
