FS: Pioneer Elite VSX-54TX (1 Viewer)
Alan Pummill
I am the original owner of this well cared for, like new receiver. This unit is cosmetically and functionally near perfect. This has been used in my 6.1 HT for 3 1/2 years, pushing 600 series B&W speakers flawlessly. I am moving up to a VSX-94TXH.
I have the original double box, remote, mic, and manual. $425 shipped to lower 48 states. No low ball offers will be looked at. Thanks all!!
Alan Pummill
This is powerful, feature-rich AV receiver that delivers serious home theater performance. Its dual Motorola 150-MIPS DSP digital core engine provides huge processing power, and its THX™ SelectTM capability ensures mind-bending theater sound and THX's assurance that the VSX-54TX meets the highest standards for build quality and technical specifications. And for the best sound possible, Advanced MCACC offers studio-quality set-up and calibration of your system, even capable of measuring and compensating for indirect sound reflections from your walls and ceiling. You can even control and visually monitor the process on your laptop via an RS232C PC interface. Dolby Pro-Logic® IIx can create an amazing 7.1 channels from 2-channel sources, putting new life into older material. Multi-Room lets you control the VSX-54TX from another room via remote, and Multi-Source enables control of multiple sources (such as CD player and tuner) by multiple users. The 110-watt x 7 VSX-54TX comes with 10 A/V inputs, and a pre-programmed remote (with macro commands).
Power
Amplifier Design A.D.E MOS FET
Surround Power 110 W x 7 (20HZ - 20kHZ @ 8 ohm, 0.09% THD)
Stereo Power 110 W x 7 (20HZ - 20kHZ @ 8 ohm, 0.09% THD))
Audio Processing
Digital Engine Dual Motorola 48-Bit Processing
Air Studios TMTuning
Room Calibration Y
Advanced Surround Modes Y
THX Select2
Dolby(R) Digital EX
DTS-ES
Dolby(R) Digital 5.1
DTS(R) 5.1
DTS NEO: 6
Dolby Pro-Logic IIx
Virtual Surround Back
Midnight Listening
Loudness
Analog to Digital Conversion 96 kHz / 24-Bit
Digital Analog Conversion (DAC) 192kHz/24-Bit Delta Sigma
Convenience
On-Screen Display Yes - All
Remote Universal
Multi Operation
Connectivity
Component Video Input 2
Component Video Outputs 1
S-Video Input 5
S-Video Outputs 3
Composite A/V Input 5
Composite A/V Output 3
Analog Audio Inputs 10
Analog Audio Outputs 4
Digital Inputs 5
Digital Outputs 2
Multi-Channel Input 8 Channel
Audio Pre-Output 8 Channel
Headphone Output
Multi-Room and Source Output 1 A/V
12 Volt Trigger (Device Assignable) Yes
Front A/V Inputs
RS-232C
AC Outlet
SR+
Construction
Front Panel Aluminum
Transformer Stabilizer
3-D Space Frame Design
Direct Construction
Warranty
Warranty 2 years parts and labor
Dimensions
Dimensions (inches) 16 9/16 x 7 7/16 x 18 5/16 (WxHxD)
Dimensions (mm) 420 x 188 x 464 (WxHxD)
Weight 39.7 lbs.
phyllisbernhard
