FS: Pioneer 811s and Parasound HCA855a
Discussion in 'Hardware Classifieds' started by ChadLB, Jul 14, 2004.
  1. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    That is correct I am selling off my Pioneer 811s(Original Owner). Price: $150 + Shipping.
    Power
    * Stereo: 100 Watts x 2
    * Surround: 100 Watts x 6
    Digital Decoding and Processing
    o Crystal Digital Signal Processing
    o DTS-ES Discrete 6.1 Decoding
    o DTS NEO 6: Music & Cinema Surround Decoding
    o Dolby Digital EX 6.1 Surround Decoding
    o Pro-Logic II Music & Movie Surround Decoding
    o 96kHz/24-Bit Digital to Analog Conversion
    o 5 Advanced Surround Modes
    + Expanded 6.1
    + 6-Channel Stereo
    + Music
    + Movie
    + Virtual Surround Back
    o Midnight Mode
    Connectivity
    o DVD-Audio Ready
    o 7.1 Channel Inputs
    o Pre-Amp Output ALL Channels
    o 5 Digital Inputs (3 optical/2 coaxial back, 1 optical front) / 1 Digital Out (optical)
    o Inputs - 4 Audio/4 Audio/Video
    + CD
    + AUX
    + CDR/TAPE/MD
    + TUNER
    + DVD/LD
    + TV/SAT
    + VCR/DVR
    + VIDEO (Front Panel)
    o Outputs - 1 Audio/1 Audio Video/1 Video
    + CDR/TAPE Audio Output
    + VCR/DVR Audio/Video Output
    + Monitor Video Output
    o Component Video Switching (2 Inputs/1 Output)
    + TV/SAT Input
    + DVD/LD Input
    + Monitor Output
    o S-Video (4 Inputs/2 Outputs)
    + DVD/LD Input
    + TV/SAT Input
    + VCR/DVR Input
    + Video (Front Panel) Input
    + VCR/DVR Output
    + Monitor Output
    o Independent A/B Speaker Switching
    o Heavy Duty Banana Speaker Binding Posts
    o Dual Surround Back Speaker Terminals for 7.1 Speaker Set-up
    Convenience
    o Front Panel Quick Set-Up w/ Jog Control
    o Auto Signal Select
    o 30 Preset AM/FM Digital Tuner
    o AM/FM Station Name Input
    o Semi-Dot Matrix Display
    o Front Panel Door
    o Preprogrammed and Smart Remote
    + TV
    + VCR
    + DVD
    + Cable Box
    + Digital Satellite Tuner
    + Multi-CD Control
    Dimensions
    o Width: 16-9/16"
    o Height: 6-4/16"
    o Depth: 15-6/16"
    Parasound HCA855a(2nd Owner - great shape) $375 + Shipping
    Features
    Specifications
    * Direct coupled - no capacitors or inductors in signal path
    * DC Servo and relay protection circuits
    * High bias Class A/AB operation
    * 1 kVa Toroid power transformer with independent secondary windings for each channel, 68,000 µF power supply filter capacitance
    * Independent power supplies for each channel
    * Input stages use hand matched complementary JFETs
    * 20 matched 15 amp, 50 MHz bipolar output transistors
    * AC present, standby/normal, current overload indicators
    * Rear mounted gain controls and rear handles
    * 12 volt DC automatic turn-on circuitry Gold-plated metal structure RCA input jacks
    * Gold-plated 5 way speaker binding posts
    * Custom designed removable IEC AC cord
    * Three rack space height front panel
    * Rack mounting adapter available (RMK-3)
    * Continuous Power Output: 85 watts RMS x 5, 20 Hz-20 kHz, 8 ‡; 125 watts RMS x 5, 20 Hz-20 kHz, 4 ‡
    * Current Capacity: 30 amps peak per channel
    * Slew Rate: > 130 V/microsecond
    * Power Bandwidth: 5 Hz-100 kHz, +0/-3 dB at 1 watt
    * Total Harmonic Distortion: < 0.03 % at full power; < 0.01 % typical levels
    * IM Distortion: < 0.03 %
    * TIM: Unmeasureable
    * Dynamic Headroom: > 1.5 dB
    * Interchannel Crosstalk: > 80 dB at 1 kHz > 60 dB at 20 kHz
    * Input Impedance: 33 kW
    * Input Sensitivity: 1 V for 28.28 V 1.2 V for full output
    * S/N Ratio: > 115 dB, full power, IHF A-weighted
    * Damping Factor: > 800 at 20 Hz
    * Dimensions: 17" wide x 5 1/4" high x 16" deep (6" high with feet)
    * Power Requirements: 110 Vac-120 Vac 750 Watts
    * Net Weight: 41 lb
    I will accept payment via money order Or Paypal.
    Any questions PM me.
  2. Lucian
    Lucian Stunt Coordinator
    Dec 1, 2003
    74
    Where are you located? Maybe a pickup is possible.
  3. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Zip Code is 54115(Wisconsin).
    Any questions on the items/pictures needed please let me know.
  4. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Bump'n[​IMG]
  5. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Parasound sale is Pending.....
  6. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Pioneer is sold...
    Parasound amp is Pending sale again....
