Frank Carter
- Mar 12, 2002
$375 Parasound HCA-855a brand new in factory sealed box.
$35 S&H (very heavy)
I'll inlcude a copy of my receipt so you will have a valid 10 year warranty through Parasound.
Instead of buying a higher priced receiver, I bought a less expensive receiver w/pre-outs added this amp and voila! Unbeatable sound at an unbeatable price.
You can checkout my ebay feedback rating under seller name: Link Removed
FEATURES
Direct coupled - no capacitors or inductors in signal path
DC Servo and relay protection circuits
High bias Class A/AB operation
1 kVa Toroid power transformer with independent secondary windings for each channel, 68,000 µF power supply filter capacitance
Independent power supplies for each channel
Input stages use hand matched complementary JFETs
20 matched 15 amp, 50 MHz bipolar output transistors
AC present, standby/normal, current overload indicators
Rear mounted gain controls and rear handles
12 volt DC automatic turn-on circuitry Gold-plated metal structure RCA input jacks
Gold-plated 5 way speaker binding posts
Custom designed removable IEC AC cord
Three rack space height front panel
SPECIFICATIONS
Continuous Power Output: 85 watts RMS x 5, 20 Hz-20 kHz, 8 ‡; 125 watts RMS x 5, 20 Hz-20 kHz, 4 ‡
Current Capacity: 30 amps peak per channel
Slew Rate: > 130 V/microsecond
Power Bandwidth: 5 Hz-100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion: < 0.03 % at full power; < 0.01 % typical levels
IM Distortion: < 0.03 %
TIM: Unmeasureable
Dynamic Headroom: > 1.5 dB
Interchannel Crosstalk: > 80 dB at 1 kHz > 60 dB at 20 kHz
Input Impedance: 33 kW
Input Sensitivity: 1 V for 28.28 V 1.2 V for full output
S/N Ratio: > 115 dB, full power, IHF A-weighted
Damping Factor: > 800 at 20 Hz
Dimensions: 17" wide x 5 1/4" high x 16" deep (6" high with feet)
Power Requirements: 110 Vac-120 Vac 750 Watts
Net Weight: 41 lb
FEATURES
SPECIFICATIONS
TIM: Unmeasureable
Net Weight: 41 lb
