FS: Parasound HCA-855A - $375
Discussion in 'Archived Threads 2001-2004' started by Jeff Harlow, Aug 7, 2002.
  1. Jeff Harlow
    Jeff Harlow Auditioning
    Aug 6, 2002
    10
    When I bought this amp I intended to buy a receiver to use as a pre/pro. I ended up with a Marantz 8200 and am happy with the internal amps so I am selling the Parasound 855. The amp is new and has only been removed from the box to make sure all channels are in working order. I will also include the 12V DC trigger cable which is somewhat non-standard.
    $375 Parasound HCA-855a. Buyer to pay actual S&H
    Comes with full 10-year warranty.
    Email me at [email protected]
    FEATURES
    Direct coupled - no capacitors or inductors in signal path
    DC Servo and relay protection circuits
    High bias Class A/AB operation
    1 kVa Toroid power transformer with independent secondary windings for each channel, 68,000 µF power supply filter capacitance
    Independent power supplies for each channel
    Input stages use hand matched complementary JFETs
    20 matched 15 amp, 50 MHz bipolar output transistors
    AC present, standby/normal, current overload indicators
    Rear mounted gain controls and rear handles
    12 volt DC automatic turn-on circuitry Gold-plated metal structure RCA input jacks
    Gold-plated 5 way speaker binding posts
    Custom designed removable IEC AC cord
    Three rack space height front panel
    SPECIFICATIONS
    Continuous Power Output: 85 watts RMS x 5, 20 Hz-20 kHz, 8 ‡; 125 watts RMS x 5, 20 Hz-20 kHz, 4 ‡
    Current Capacity: 30 amps peak per channel
    Slew Rate: > 130 V/microsecond
    Power Bandwidth: 5 Hz-100 kHz, +0/-3 dB at 1 watt
    Total Harmonic Distortion: < 0.03 % at full power; < 0.01 % typical levels
    IM Distortion: < 0.03 %
    TIM: Unmeasureable
    Dynamic Headroom: > 1.5 dB
    Interchannel Crosstalk: > 80 dB at 1 kHz > 60 dB at 20 kHz
    Input Impedance: 33 kW
    Input Sensitivity: 1 V for 28.28 V 1.2 V for full output
    S/N Ratio: > 115 dB, full power, IHF A-weighted
    Damping Factor: > 800 at 20 Hz
    Dimensions: 17" wide x 5 1/4" high x 16" deep (6" high with feet)
    Power Requirements: 110 Vac-120 Vac 750 Watts
    Net Weight: 41 lb
  2. Donnie Eldridge
    Donnie Eldridge Supporting Actor
    Jan 3, 2001
    761
    ygm
  3. Phill O
    Phill O Stunt Coordinator
    Mar 11, 2001
    128
    Hey Don, I recently got one of these amps from another
    fella here in the forum. It sound great with my NHT 2.5i,
    I got them bi-amped! Now I need to get that Pre-pro....
    I have been very happy with this amp so far. BUT at
    85 watts a channel this thing still weighs in at over
    40 pounds, it's no light weight! [​IMG]
  4. Chris Carswell
    Chris Carswell Supporting Actor
    Mar 5, 2002
    598
    Jeff,
    You still got that thing?
  5. Jeff Harlow
    Aug 6, 2002
    10
    SOLD!
