Jonathan DA
- Jan 11, 2002
One pair of lightly used NHT 1.5 two-ways. Gloss black laminate finish. Originally $600, will sell for $295 plus shipping from zip 78664. Timbre matched to all the NHT Music Series speakers, i.e. 2.5, 2.9, 3.3.
System Type: 2-way acoustic suspension.
Drivers: 6.5" long throw polypropylene woofer and 1" aluminum dome tweeter (video shielded drivers).
Frequency Response: 53 Hz. -25 kHz. (± 3 dB).
Sensitivity: 85 dB @ 2.83V (1 Watt/1 Meter).
Impedance: 8 ohms nominal (7.5 minimum).
Recommended Amplifier Power: 20-150 watts/channel.
Physical Dimensions: 16.5" (41.25 cm.) H. x 7.0" (17.5 cm.) W. x 10.25" (25.625 cm.) D.
Weight: 16lbs each
Finish: High-gloss black laminate.
Weight: 16lbs each
