Kevin Alexander
- Apr 17, 1999
150 watts x 5 channel power output (into 8 ohms), featuring fully discrete output topology with high-current output transistors. The MM-9000 can drive even difficult loudspeaker loads with ease. Oversized power supply featuring a massive toroidal transformer and high-capacity electrolytic capacitors, for generous power reserves even when reproducing demanding action movie soundtracks at high volumes. Premium-quality internal components used throughout for maximum signal purity. The MM-9000 reproduces movie soundtracks and surround sound music discs with extraordinary clarity, resolution and dynamic range. The MM9000 is equipped with peak power indicators which indicate when the amplifier has attained maximum power. THX Ultra certified-the highest level of THX certification available, given only to audio/video components that meet the very highest standards of performance and sound quality.
*150 watts (into 8 ohms) x 5 channel power output
*Oversized high-capacity toroidal transformer
*Premium quality internal components
*THX Ultra® certified
*Individual input level control
*3 auto power on/off options – via DC trigger, video-sense
connections, or via wireless remote control
*D-BUS remote connection
*Peak level indicators
*Heavy-duty banana plug-compatible speaker terminals
*AC convenience outlet
This unit is brand new in a sealed box. Excellent sound and very powerful. Price: $650 shipped. Send me an email if you're interested and thanks for looking.
