FS: Lutron Spacer System Dimmers, Remote, Lamp Dimmer
Discussion in 'Hardware Classifieds' started by Cornelius, Mar 11, 2004.
  1. Cornelius
    Cornelius Stunt Coordinator
    Feb 24, 2004
    117
    I have the following Spacer System components for sale. These are not the cheaper Spacer dimmers that are sold in Home Depot, these dimmers are scene capable! All are brand new and still in the box. If you want all 8 dimmers, I'll throw in the 4-scene remote control and the lamp dimmer for free (if they haven't already been sold).
    8- SPS-600-WH Single-pole, scene-capable dimmers $55 ea.
    1- SPS-300LD-RP Lamp dimmer $55
    1- SPS-4IT-RP 4-scene remote control $60
    You can find more about them at http://www.lutron.com/spacer/SpSystemDefault.htm
    My ebay user ID is bmw4u2 (152 positives, 0 negatives, 0 neutrals).
    CJ
    coneilliv at aol dot com
  2. Chris Muollo
    Chris Muollo Stunt Coordinator
    Dec 15, 2002
    60
    YGM...
  3. Cornelius
    Feb 24, 2004
    117
    Due to Chris's lighting requirements, still forsale.
    CJ
  4. smarthdl
    smarthdl Auditioning
    Sep 26, 2009
    2
    Smart HDL the new leader brands for Home Automation and life style in the world, offers many solutions under one roof and one brand for Lighting, security, Music, curtain, Air condition control, Infrared control, Audio video, User interface, Power meters, SMS and remote control, Timers and Logic, IO analog and digital.
    If you are familiar with such system
    like Crestron AMX, HAI, Dynalite, clipsal, RCS, Lutron, Lite touch ++, you can see how smart and flexable the new smart HDL brand for smart bus system is.
    1 - Lighting control: Din rail, and mountable Dimmers and relays, proudly our Product can work in both 110 V and 220 V, 50 and 60 HZ, its green product operated by 24V DC.
    a - Din rail dimmers 2 CH 6 A, 4 CH 3 A, 6 CH 2A
    b - Wall Mount dimmers 12 CH 10A , 6 Ch 10 A, 6 CH 20 A
    c - Din rail Relay 8 CH 16 A, 4 CH 20 A, 8 Ch 10 A, 4 ch 10 A
    d - DALI , and Ballast controller
    e - We are the first in stage Lighting and DMX Control for big projects like the last Olympics, or for home small disco lighting with our unique DIY touch screen allowing the client to record his party lighting and music and play it when the party start
    2 - Air condition control: we can control all type of AC, in our AC module you can control Single and Multi stage unit, 3 fan speed and VAV 0-10 Volt control, 4-20 mA , with external temp sensor terminal. What we can control regarding AC is:
    a - Split AC unit by IR control
    b - HVAC Fan compressor Relays
    c - VAV 0-10 V, 4-20 mA
    d - Lon works
    e - Any 3rd party AC system integrated by rs485, or rs232
    3 - Curtain and shade control, our shade is bus enabled no need to run electrical wiring fro automation, and we have all type of shade motors blind vertically and horizontally curtain. Our curtain features is:
    a - Bus enabled (save wiring and conduits)
    b - Can carry up to 120 KG
    c - Can be stand alone with its 4 daily timer
    d - IR remote to integrate with any system
    e - Dry contact for integration to other 3rd party system
    f - Free Clutch; work in manual and automatic together in same Time.
    4- User interface, let me tell you about our Dynamic page LCD Panel, and you will see how old and useless the system you were using.
    Our LCD Panel in 1 panel only can do the following:
    a - Consist of more than 15 dynamic pages for all functions
    b - Control the Lighting channel on off
    c - Dim the lighting channel (keep pressing function).
    d - Double click function to go to any mode you like
    e - Control scene and can dim the scenes
    f - Have built in temperature sensor, with adjustable technology
    g - AC page controlling the heating cooling fan speed and desire temperate with Auto Mode
    h - Control up to 8 others panel as slave for AC. Can be master slave, or master.
    i - Controlling the IR for TV, DVD and others devices
    j - Controlling the curtain
    k - Arming disarming the security system from your panel
    l - Music control, you can see the song name album and Genres, select next track pause, play and change the volume.
    m - You can set your clock alarm and medicine alarm that trigger ever couples of hours; we care about your health.
    n - It supports all language in the world, English, Spanish, French, German, Arabic, Chinese, Russian, Turkish, Urdu …..
    o - It support picture on its page for more friendly use
    p - It have time and date showing in your LCD
    q - It can be locked by password or locked by other commands.
    r - It have IR receiver, controlled remotely.
    s - It is 2 way for lighting security, AC, Curtain and music
    t - Backlit and LED adjustable and auto backlit on depend on motion sensors
    u - Much more from A-Z and still the list not finish all this in 1 small panel in the wall.
    Also smart-HDL has other interface like 2-4-6 button Panel, touch screen and much more for interface.
    5 - Home Automation, we have our advanced home Automation system. We have our Logic module that have 240 Logic table of AND, OR, Nand and xor, that can link all the logic you need.
    1 - At time, sunset sunrise, before after time sunset sunrise. time between …. To..
    2 - When scene, sequence , channel on , channel off, curtain on off
    3 - When flag on off delay time….
    4 - When Temp value range between …. To …..
    5 - When date, between dates …. Date
    6 - When days Sunday Monday …….
    7 - When security OFF, Vacation, Night ++++
    8 - Link between tables …
    Also we are proudly and uniquely have our 6 IN 1 Sensor installed in ceiling very small and elegant with a lot of function
    a - It have Motion Sensor
    b - Light intensity sensor
    c - IR receiver
    d - 360 degree IR Sender
    e - 2 dry contact to connect to Door window or smoke detector in the room
    f - It have 32 logic table inside it to link all this function
    g - It support security
    h - It is bus enabled
    Our system Logic is in all our products, all of it is smart and co-operate together, the system will never stop hung or respond slow
    6 - Security , we have our bus security module that can support the following
    a - More than 250 000 security zones
    b - Can be divided to 8 different security area
    c - Support all type of NO, NC sensors Vacation Away Night, Night with Guest , Day , Fire Panic Temp Alarm
    d - Auto Arm and disarm depend on the Arming mode
    e - Vacation mode to secure your house by saving your furniture and randomly open lights in your home during your absence
    f - Bypass and restore the zones , alarm events history
    7 - Others , need more, We have a lot of other products I can list to you some
    a - Bus GPRS Module to control your home by SMS and the home inform you if any problem
    b - Power Meter to know the consumption of your electricity day by day hour by hour and month by month, and it will send you alert if the consumption is high
    c - RS232 485 for integration with 3rd party device, we have our own protocol and can receive and send any ASCII command in any baud rate, we can control HEX also. (NUVO Music system integrated ready with our system)
    d - IR control with current sensor
    e - Room partioner
    f - 4 input sensor for security or Automation
    g - IO module for analogue and digital input and output
    All this you can finish it installation and programming in very easy and short time (2-3 Days for the project)
    For more info, Manuals, Films and others you can visit our website www.smart-hdl.com
    For installation and Programming Film you can visit www.youtube.com/sbustraining
  5. smarthdl
    Sep 26, 2009
    2
    Smart HDL intrduce the latest Technology in the world, for its Magical Dynamic page LCD Panel for Lighting and home automation system.
    You can see some of the Functions and features of your future Technology listed down:
    a - More control, Consist of more than 15 dynamic pages for all functions
    b - Classical, single press Controlling the Light channel ON/OFF.
    c - Convenience, Dim, Ramp the lighting channel (keep pressing function)
    d - Advanced, Double click function to Run any mode scene or functions you like, Lift and Right press for different Function for each Button.
    e - Powerful, Control scene and ability to dim the scenes
    f - Real room Temp, built in temperature sensor, with adjustable calibration technology.
    g - Minimizing, AC page controlling all type of AC units like relays, VAV 0-10 V, and split AC unit , setting your mode cooling heating fan speed , your desire temperate with Auto Mode.
    h - Solutions, Control up to 8 others panel as slave for AC. Can be master slave, or master master.
    i - Entertain, Controlling the IR for TV, DVD , and other Appliances, selecting movie and run the party.
    j - More options, Controlling the curtain
    k - Safety, Arming disarming the security system from your panel in Vacation, Away night, day, mode, with panic button, calling emergency and fire Panic.
    m - Health, your clock alarm and medicine Remainders that trigger every couple of hours; emergency button to call your doctor and send SMS , this Magical Panel care about your health.
    n - For Every Nationality, It supports all language in the world, English, Spanish, French, German, Arabic, Chinese, Russian, Turkish, Urdu and others.
    o - For all ages, Friendly use, it support picture on its page for easy understanding.
    p - Time is important, it have time and date showing in your LCD
    q - Advanced Security, it can be locked by password or locked by other commands.
    r - Remote control, it have IR receiver, controlled remotely.
    s - Informative, it is 2 way for lighting security, AC, Curtain and music
    t - Smart, Backlit and LED adjustable and auto backlit on depend on motion sensors
    u - Flexibility, fit in all standards, Australian/US, UK, EP standards.
    v - Easy to maintain, Screw less mountings using advanced Magnetic Attach idea
    w - Elegant, Flexible finishes available as stainless, golden, glass, wood, Marble ++
    x - Saving Energy, Time out default page and screen saver mode
    y - High Quality, 8-24 V Bus Device, saving your wires money, and long range of operating voltage in case of voltage drop in long wire it still can work.
    z - Need More !!, Much more from A-Z and still the list not finish more functions will be available always, all this in 1 small panel in the wall.
