Steve F M
- Jul 17, 2003
This was put together with all new parts and I built 2 of them. I will check to make sure everything works but here's what you get. I will include all box's and Software. Has HDMI, DVI, and VGA Out along with SPDIF incase you arent using the HDMI.
Case - Theraltake Tenor HTPC Box (Black)
CPU - AMD X2 Dual Core 5200+
Motherboard - GIGABYTE GA-MA69G-S3H AM2 AMD 690G HDMI ATX AMD
Memory - 4 GB of DDR2 5300 667Mhz
Power Supply - Coolmaster eXtreme Power 550W
Hard Drive - Seagate 320GB Sata
DVD Burner - Asus Litescribe 18x DVD Burner (Etches images in DVD's)
Blue-Ray/HDDVD - LG GGC-H20L Blue-Ray/HDDVD Player
Software - Vista Premium(Will send DVD and serial # along)
Software - Power DVD Ultra needed for Blue-Ray/HDDVD
As you can see this is loaded and plays both Blu-Ray and HDDVD's. The Power DVD software alone is a $100 and the nice thing about the drive is it has the auto firmware update for any new movies that come out. The Combo Drive supposedly burns regular DVD's but I threw a Litescribe Burner on there as I like the Lightscribe feature.
I won't sell for any less then $1100 shipped as everything cost wise I will break about even after shipping.
