FS: Klipsch KSW100 sub
Discussion in 'Archived Threads 2001-2004' started by Mike Loiterman, Jul 18, 2002.
  1. Mike Loiterman
    Mike Loiterman Stunt Coordinator
    Jan 24, 2000
    212
    $200 obo.
    KSW 100
    Type: 8" Bass-Reflex Enclosure
    Amplifier: 100 Watts continuous into 4 ohms
    Auto Power on: 2 second on delay, 15 minute off delay
    Dynamic Headroom: 1 dB (I 25 Watts into 4 ohms)
    Frequency Response: 34 - 120 Hz ± 3 dB
    Maximum Output: 101 db
    Audio/Video Switch:
    +3 dB over entire frequency response.
    Low Pass Crossover:
    Continuously variable from 40 - 120 Hz, 24 dB/Octave slope above 120 Hz
    High Pass Crossover (main speakers):
    Line level outputs with switchable high pass
    Between 40 & 80 Hz, 6 dB/Octave slope
    120 Hz. Speaker level outputs with fixed
    high pass at 100 Hz. 6 dB/Octave slope.
    Phase: Switchable 0 – 180 degrees
    Inputs/Outputs: line level RCA phone jacks
    High level speaker terminals
    Drive Component:
    K-1048-K8” (20.3cm) driver
    Dimensions:14,75" H x 13.5" W x 13.5" D (with feet)
    37.5 cm H x 34.3 cm @'x 34.3 cm D
    Weight: 39 lbs. - 17.7 kg with packaging
    Cabinet: Medium Density Fiber board construction (MDF)
    Finishes: Matte finish black vinyl
    Voltage: 110/120VAC/6O Hz
  2. Marc Alexander
    Marc Alexander Stunt Coordinator
    Mar 3, 1999
    134
    My best offer is $100 but that is undercutting your asking price quite a bit. Send me a message if you don't get a better offer.
